> The LED2 = 1 instruction will not be an atomic instruction when done
> using bit fields.
> Use:
> #define LED2 (1<<12)
> port0_set = LED2
> makes use of the special I/O set register. This is faster (it saves a
> read from port0_reg) and atomic
This may be informative for some. I compiled two lines of the same code
that lie at the start of a function.
#define LED31_BIT 31
#define LED31_BIT_MSK 0x80000000
(Bit Field Method as referenced in earlier post)
LED1 = LED_OFF;
LDR R4,??main_0+0xC ;; port_reg
LDR R0,[R4, #+0]
MVN R1,#+0x2000
LDR R2,[R0, #+0]
AND R2,R1,R2
STR R2,[R0, #+0]
LED1 = LED_OFF;
LDR R2,[R0, #+0]
AND R1,R1,R2
STR R1,[R0, #+0]
FIO0PIN |= (1 << LED31_BIT); // read and write
MVN R0,#-1073741781
BIC R0,R0,#+0x3FC0
LDR R1,[R0, #+0]
ORR R1,R1,#-2147483648
STR R1,[R0, #+0]
LDR R1,[R0, #+0]
STR R1,[R0, #+0]
FIO0PIN |= LED31_BIT_MSK; // read and write
MVN R0,#-1073741781
BIC R0,R0,#+0x3FC0
LDR R1,[R0, #+0]
STR R1,[R0, #+0]
LDR R1,[R0, #+0]
STR R1,[R0, #+0]
FIO0SET = (1 << LED31_BIT); // write only
MVN R0,#-1073741785
BIC R0,R0,#+0x3FC0
MOV R1,#-2147483648
STR R1,[R0, #+0]
STR R1,[R0, #+0]
FIO0SET = LED31_BIT_MSK; // write only
MVN R0,#-1073741785
BIC R0,R0,#+0x3FC0
MOV R1,#-2147483648
STR R1,[R0, #+0]
STR R1,[R0, #+0]
Joel
