Lpc2000
SOS please help
SOS please help
2006-01-09 by vicky gosar
hi,
  this is vicky from india
  i am working on the LPC2106 philips ic
  I am having problems in executing timer interrupts
  the timer interupt doesnt go to the ISR & the system stops responding.
  i have attached the source file with the mail
  if anybody can help with same program code please help
  Vicky
Send instant messages to your online friends http://in.messenger.yahoo.com
// Copyright (c) 2001-2004 Rowley Associates Limited.
// This file may be distributed under the terms of the License Agreement
// provided with this software.
// THIS FILE IS PROVIDED AS IS WITH NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
//                    Philips LPC210X - UART Example
// Description
// This example demonstrates configuring and writing to a UART. It also
// demonstrates how to get printf output over the UART by implementing
// __putchar.
// To see output:
//   - Connect serial cable from UART0 connector on your target board to your
//     host computer.
//   - Open CrossStudio's "Terminal Emulator Window". Configure it to 9600 baud,
//     8 data bits, no parity, 1 stop bits. Click "Connect" to start the
//     terminal emulator window.
#include <targets/LPC210x.h>
#include <stdio.h>
//#include <ctl_api.h>
static int timer0Count, timer1Count;
static unsigned int processorClockFrequency();
static unsigned int peripheralClockFrequency();
static void delay(int n);
static void UARTInitialize(unsigned int baud);
static void UARTWriteChar(unsigned char ch);
static unsigned char UARTReadChar();
void __putchar(int ch);
static void ledInit();
static void ledOff();
static void ledOn();
static void tim_init(void);
static unsigned int
processorClockFrequency(void)
  return 14.7456 * 1000000 * (PLLCON & 1 ? (PLLCFG & 0xF) + 1 : 1);
static unsigned int
peripheralClockFrequency(void)
  unsigned int divider;
  switch (VPBDIV & 3)
      case 0:
        divider = 4;
        break;
      case 1:
        divider = 1;
        break;
      case 2:
        divider = 2;
        break;
  return processorClockFrequency() / divider;
static void
delay(int n)
  volatile int i;
  for (i = 0; i < n; ++i);
static void
  unsigned int divisor = peripheralClockFrequency() / (16 * baud);
  U0LCR = 0x83; /* 8 bit, 1 stop bit, no parity, enable DLAB */
  U0DLL = divisor & 0xFF;
  U0DLM = (divisor >> 8) & 0xFF;
  U0LCR &= ~0x80; /* Disable DLAB */
  PINSEL0 = PINSEL0 & ~0xF | 0x5;
  U0FCR = 1;
static void
  while ((U0LSR & 0x20) == 0);
  U0THR = ch;
UARTReadChar(void)
  while ((U0LSR & 0x01) == 0);
  return U0RBR;
void
__putchar(int ch)
  if (ch == '\n')
    UARTWriteChar('\r');
  UARTWriteChar(ch);
static void
ledInit()
  IODIR |= 0x00000080;
  IOSET = 0x00000080;
static void
ledOff(void)
  IOCLR = 0x00000080;
static void
ledOn(void)
  IOSET = 0x00000080;
static void timer0ISR(void) __attribute__ ((interrupt ("IRQ")));
static void
timer0ISR(void)
  if (++timer0Count % 2)
    ledOn();
  else
    ledOff();
  /* Clear the timer 0 interrupt */
  T0IR = 0xFF;
  /* Update VIC priorities */
  VICVectAddr = 0;
static void timer1ISR(void) __attribute__ ((interrupt ("IRQ")));
static
void
timer1ISR(void)
  ++timer1Count;
  /* Clear the timer 1 interrupt */
  T1IR = 0xFF;
  VICVectAddr = 0;
static void
tim_init(void)
//   T0IR = 0;
//   T1IR = 0;
     T0IR = 0x00000000;
     T1IR = 0x00000000;
   T0TC = 0;
   T1TC = 0;
/* Timer 0 interrupt is an IRQ interrupt */
  VICIntSelect &= ~0x10;
  /* Enable timer 0 interrupt */
  VICIntEnable = 0x10;
  /* Use slot 0 for timer 0 interrupt */
  VICVectCntl0 = 0x24;
  /* Set the address of ISR for slot 0 */
  VICVectAddr0 = (unsigned long)timer0ISR;
  /* Timer 1 interrupt is an IRQ interrupt */
  VICIntSelect &= ~0x20;
  /* Enable timer 1 interrupt */
  VICIntEnable = 0x20;
  /* Use slot 1 for timer 1 interrupt */
  VICVectCntl1 = 0x25;
  /* Set the address of ISR for slot 1 */
  VICVectAddr1 = (unsigned long)timer1ISR;
  /* Reset timer 0 */
  T0TCR = 0;//timer Control register
  /* Set the timer 0 prescale counter */
  T0PR = 2500000;
  /* Set timer 0 match register */
  T0MR0 = 10;
  /* Generate interrupt and reset counter on match */
  T0MCR = 3;
  /* Start timer 0 */
  T0TCR = 1;
  /* Reset timer 1 */
  T1TCR = 0;
  /* Set the timer 1 prescale counter */
  T1PR = 2500000;
  /* Set timer 1 match register */
  T1MR0 = 10;
  T1MCR = 3;
  /* Start timer 1 */
  T1TCR = 1;
  T0IR = 0;
   T1IR = 0;
int
main(void)
  int i;
  unsigned char vic;
  tim_init();
  UARTInitialize(9600);
  ledInit();
  delay(1000);
  /* Enable Interrupts */
  //__ARMLIB_enableIRQ();
  for (i = 0; ; ++i)
    printf("Hello World (%d) (%d) (%d)\n\n", i,T0TC,T1TC);
 //   printf("Vicky (%d)\n\r",i);
 //   printf("Kushal (%d)\n\r",i);
 //   printf("Bimal (%d)\n\r",i);
      //vic = UARTReadChar();
      //putchar(vic);
      if(T0IR != 0 || T1IR != 0)
       printf("Interrupt (%d) (%d)",T0IR,T1IR);
       T0IR = 0x00000000;
       T1IR = 0x00000000;
      ledOff();
      delay(100000);
      ledOn();
      delay(100000);
       return 0;
