Checksum Problem Part B
2006-01-10 by carlosahsilva
I have made some tests on the Program CheckSum generated by IAR
compiler and there is realy something fish.
First I edited the segmentation to place the CheckSum as first byte
after the end of my code:
?CHECKSUM CHECKSUM __checksum 00037FFF
Program Relative
module segment
00037FFF -
00037FFF
Segment part 1.
ROOT.
The IAR compiler informed me the value and calculation range
Checksums
Symbol Checksum Memory Start End
__checksum 0xcc CODE 00000000 - 00037FFE
I selected the simple checksum (not any CRC) and wrote the code below
to test it
CheckSum calculation routine
void CalcCheckSum(void)
unsigned char *pby;
unsigned char *pCksGen;
unsigned char CksGen;
char STRCksCalc[] = "AAAAAAAAAAAAAAAAA";
char STRCksGen[] = "AAAAAAAAAAAAAAAA";
// Indicate start of the calculation
UART_PutStringByPolling (UART0, "\n\rCalculation Start.\n\r"); /**/
UART_PutStringByPolling (UART0, "\n\r\n\r");
// Point to Address 0x00000000
pby = (unsigned char *)0x00000000;
// Start the Sum with zero
unsigned char ValCheckSum = 0;
// Sum all bytes between 0x00000000 and 0x00037FFF.
for (long byte = 0; byte < 0x00037FFF-0x00000000; byte++) {
// Read a byte and sum it
ValCheckSum += *pby;
// Increment pointer
pby++;
// Indicates the end of the calculation
UART_PutStringByPolling (UART0, "\n\rCalculation End.\n\r"); /**/
// Get the value of the CheckSum stored in the firmware
pCksGen = (unsigned char *)0x00037FFF;
CksGen = *pCksGen;
// Transform both values in string
sprintf (STRCksCalc, "%x", ValCheckSum);
sprintf (STRCksGen, "%x", CksGen);
// Send the Vavlues by the serial
UART_PutStringByPolling(UART0, STRCksCalc);
UART_PutStringByPolling(UART0, STRCksGen);
How ever when I runned the code the genarate value and calculated
values are different:
Calculation Start.
Calculation End.
22 - Calculated
cc - Generated by the compiler
Does any one call tell me what I do wrong or provide me a sample?
Thanks
