Hi! I have head the manual and discovered that the reset jump is
placed by the start up code:
__program_start
ldr pc,[pc,#24] ; Absolute jump can reach 4
GByte
; ldr b,?cstartup ; Relative branch allows
remap, limited to 32 MByte
; Vectors can be enabled by removing the comments
below or by
; using #pragma vector from C code.
org 0x04
; ldr pc,[pc,#24] ; Branch to undef_handler
org 0x08
; ldr pc,[pc,#24] ; Branch to swi_handler
org 0x0c
; ldr pc,[pc,#24] ; Branch to prefetch_handler
org 0x10
; ldr pc,[pc,#24] ; Branch to data_handler
org 0x18
; ldr pc,[pc,#24] ; Branch to irq_handler
org 0x1c
; ldr pc,[pc,#24] ; Branch to fiq_handler
As you can see the first is enable by this code. The irq handler is
and FIQ handler are commented, but they were inserted by the linker
by the pragmas:
#pragma vector=0x18
__irq __arm void IRQ_ISR_Handler (void)
and
#pragma vector=0x1c
__fiq __arm void FIQ_ISR_Handler (void)
This makes Xlink to place this calls in code and redirect the a jump
located in the first 32 bytes of RAM (where will be my actual ISR
routines jumpers).
All is OK the only thing that is not OK is why the XLINK does not
correctly computates the CRC when I choose the range:
-HFFFF
-J2,crc16,,__FirmCheckSum,CHECKSUM,1,0=(CODE)0x00-ROMEND
it only works properly if I place as below:
-HFFFF
-J2,crc16,,__FirmCheckSum,CHECKSUM,1,0=(CODE)0x20-ROMEND
Apparently the the range from 0x00 to 0x1F is not properly processed
by XLINK in the automatic CRC calculation.
--- In lpc2000@yahoogroups.com, Rob Jansen <rob@m...> wrote:
> carlosahsilva wrote:
> >I was testing the CRC16 checksum routine from Technical Note
91733
> >from IAR and it worked for all my program except the region
between
> >0x00 and 0x1F (where the interrupt vectors lie).
> Reason for this is most likely because the vector at address 0x14
> changed. This vector is ununsed in the ARM and contains a checksum
for
> the vector table (this is calculated by the download tools before
> downloading the code). Reason is that the lpc21xx will only start
> code in flash if the checksum of the table computes - to be sure
that
> only real code is executed.
> >As you can see in the segment of a hex file above the three
verctors
> >reset, IRQ and FIQ are the same 18 F0 9F E5!!!!
> As Dominic writes this is: e59ff018 ldr pc, [pc, #24]
> This is an ARM instruction that will load PC with the content of
PC + 0x24
> If you'd like to know more about this, get the datasheets from the
ARM
> website and start playing with an ARMulator (GDB includes one that
is Show quoted textHide quoted text
> mostly functional).
> Rob
