Lpc2000
UART RXD problem
UART RXD problem
2004-02-24 by Helge Fabricius-Hansen
I have a problem with the Uart of the LPC2106.
When receiving datablocks from a PC (9600,N,8,1) all data except the
last byte is ignored. If I switch to (9600,N,8,2) on the PC it works.
The LPC2106 is set for (9600,N,8,1).
I am transmitting 6 databytes: "FF FF 01 00 7F FE" from the PC and
the only thing received is: "FE"
If I use a terminal all characters are received as the should.
I have tried different settings on the FIFO but the result is the
same...
Any clues??
//Helge
Re: [lpc2000] UART RXD problem
2004-02-24 by microbit
Hi Helge,
Are you receiving polled or interruot driven ?
One possibility might be that your pointer is not advancing and thus
overwrites
received chars, so you only have the last RXd char in buffer ?
Can you put a breakpoint where you receive char, so it should break on 1st
char received, and then you can go from there.
B rgds
Kris
From: "Helge Fabricius-Hansen" <helge.fabricius@...>
To: <lpc2000@yahoogroups.com>
Sent: Tuesday, February 24, 2004 5:06 PM
Subject: [lpc2000] UART RXD problem
> Hi,
> same...
> Any clues??
> //Helge
>       Yahoo! Groups Sponsor
>             ADVERTISEMENT
>   a.. To visit your group on the web, go to:
>   http://groups.yahoo.com/group/lpc2000/
>   b.. To unsubscribe from this group, send an email to:
>   lpc2000-unsubscribe@yahoogroups.com
>   c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Sorry, skip that - didn't see the bit about 2 stop bits.
Are you saying that TXing 2 stop bits from the PC, the LPC2106 is RXing
all bytes properly ?
-- Kris
Sent: Tuesday, February 24, 2004 5:09 PM
Subject: Re: [lpc2000] UART RXD problem
> Hi Helge,
> overwrites
> B rgds
> Kris
> > Hi,
> > same...
> > Any clues??
> > //Helge
> >             ADVERTISEMENT
> > Yahoo! Groups Links
Service.
>             ADVERTISEMENT
SV: [lpc2000] UART RXD problem
It is interrupt driven. If I look in the rxbuffer I can see all the "7F"s
and I can see complete messages when using 2 stop bits on the PC.
Helge
-----Ursprungligt meddelande-----
Fr\ufffdn: microbit [mailto:microbit@...]
Skickat: den 24 februari 2004 07:10
Till: lpc2000@yahoogroups.com
\ufffdmne: Re: [lpc2000] UART RXD problem
Hi Helge,
overwrites
B rgds
Kris
> Hi,
> same...
> Any clues??
> //Helge
>             ADVERTISEMENT
Yahoo! Groups Links
The only other things I can think of is to check :
- That you're not set to 1.5 stop bits in UART.
- Check your GND on RS232, make sure it's not missing.
- Check that your RS232/logic levels are proper.
What do you mean with "all the 7F" RXd. Is that with 1 stop bit from PC ?
If so, what is it supposed to be receiving ?
7F is (in RX bit order)
0 - start bit
11111110 -7F
1 - stop bit
-- Kris
