Radim,
I have some 10 year old code on my website at
http://www.moonbounce.dk/embedded.htm
look for second last entry.
This is code running on a Philips 87C750 type device, but (if I may
say
so :-) well documented, so it should be easy to port to a LPC device.
Basically it uses an external interrupt pin for the RxD, and when a
start bit is discovered, it uses a timer to sample the individual
bits.
Carsten
--- In lpc2000@yahoogroups.com, "radim100" <radim100@y...> wrote:
> Hi,
> I need 3rd UART in my project so software UART implementation is
> obvious . I have transmitting part but does anybody has some
interrupt
> driven receiver site of code ( ANSI C or ASM is OK ). My baud
rates
> should be bellow 19200Bd.
> Thanks radim.
