Lpc2000
Optimization problem
2006-01-17 by andersryl
I have a weird problem (hmmm, what problems aren't weird?) regarding
the optimization flag in GCC.
I use GNUARN 4.0.1, Eclipse 3.0.1 and an board from Olimex for my
project. The Olimex-uC talks to a PC-app via UART 1. Work is
progreesing but then I got a Data Abort interrupt indicating
something was wrong.
So my idea was to try to debug the uC-code from Eclipse with OCD
Remote. If I do it with the code compiled with -03 (as it shouldn't
be according to James P. Lynch's excellent guide) it starts up
alright and the app talks with the PC. But when I set a breakpoint
and try to single-step through the code I get the error "Target
request failed: Target is not responding (timed out).".
OK, so lets compile the code using -O0 as the Lynch-guide tells me.
Now the application no longer talks to the PC-app at all.
Indications tells me that the UART1 clock is wrong.
Anyone that has ideas on why less optimization can cause problems
for me? I know that the -Ox are "aliases" for a bunch of
optimization-flag but I haven't looked into them.
And maybe someone can tell me why I get the error message when
debugging and compiling using -O3.
/Anders
Re: [lpc2000] Optimization problem
2006-01-17 by Tom Walsh
andersryl wrote:
>Hi,
IIRC, -O3 is a synonym for -Os, and if you can debug the code produced
under -Os, more power to you!  If I need to debug a section of the
program I'm working on, I turn off all optimizations: -O0.
TomW
>/Anders
>Yahoo! Groups Links
RE: [lpc2000] Optimization problem
2006-01-18 by Bruce Paterson
> regarding the optimization flag in GCC.
> OCD Remote. If I do it with the code compiled with -03 (as it
> shouldn't be according to James P. Lynch's excellent guide)
> it starts up alright and the app talks with the PC. But when
> I set a breakpoint and try to single-step through the code I
> get the error "Target request failed: Target is not
I get this error message now as well in Insight (or it thinks the target
has continued running) I think it correlates with moving to the newer
OCDremote which handles hardware breakpoints. So one step forward
(hardware breakpoint support) and one back (stuffed after 1 breakpoint).
I haven't had time to investigate further; it may be a hardware problem
with the PC I'm using as someone stole the PC I was using for debugging.
Bruce
