Re: [lpc2000] Digest Number 928
2006-01-17 by Steve Franks
I'm not sure from your message what you are exactly wanting, but I did write an I2S to paralell (8 bit gpio) converter in VHDL for a cheap CPLD a while back - http://www.opencores.org/projects.cgi/web/i2sparalell/overview Best, Steve ________________________________________________________________________ > > Message: 10 > Date: Tue, 17 Jan 2006 13:27:33 +0100 > From: "Michal Krestan" <krestan@...> > Subject: PCM > > > > I've got some problem with one application, where I have LPC2103. I need > to sample and replay audio stream in length about 20sec, but audio > interface is in PCM frame coding with 200kHz clock cycle and 16bit width. > Data will be stored into external dataflash. Clocks are generated by audio > PCM codec. Does anybody have software emulation for PCM or any idea of chip > for interfacing between PCM stream and SPI or UART? > > Michal > > [Non-text portions of this message have been removed]
