Lpc2000
How to get a function running in RAM (Lpc21xx+GnuArm)?
2006-01-18 by arkeryd
I am using uVision3 ide together with GnuArm compiler on LPC21xx.
I need to have some interrupts enabled while using the IAP functions,
and therefore have to place some interrupt service routines in RAM.
I have been looking around in documents and example files, but have
not found any solid info on this yet.
Any example, or hint of how to achieve this would be much appreciated!
(I suppose reading the generic gnu linker manual would do it, but am
afraid that the info is not so straightforward... Maybe I am too
prejudicial?)
/ Dennis
Re: How to get a function running in RAM (Lpc21xx+GnuArm)?
2006-01-18 by Karl Olsen
> functions, and therefore have to place some interrupt service
> routines in RAM.
> appreciated!
Put it in the .data section, and the startup code should copy it from
flash to RAM, just like initialization values for initialized data.
You'll get some assembler warnings "Warning: ignoring changed section
attributes for .data" that I haven't found out how to silence.  It
works for me.
void ramfunc (int i) __attribute__ ((section(".data")));
You cannot call such functions directly from flash functions (or call
flash functions from RAM functions) because RAM and flash are further
apart than a BL instruction can reach.  You can use calls through
function pointers instead.
Karl Olsen
RE: [lpc2000] Re: How to get a function running in RAM (Lpc21xx+GnuArm)?
2006-01-18 by Dan Beadle
IAR does this even simpler - use the __ramfunc declarator on the
function.  It is all auto-magic.
In LPC, it doesn't matter - RAM and FLASH are essentially the same speed
(barring branches).  But on other ARMs, Flash may be very slow, so
copying to RAM is important for critical routines.
  _____
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of Karl Olsen
Sent: Wednesday, January 18, 2006 2:14 AM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Re: How to get a function running in RAM
(Lpc21xx+GnuArm)?
> routines in RAM.
> appreciated!
works for me.
Karl Olsen
SPONSORED LINKS
Microprocessor
<http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2
=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=9
3&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
Microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&
w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s
=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
Pic microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microproces
sor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c
=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
8051 microprocessor
<http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocess
or&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=
4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000
<http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
Re: [lpc2000] How to get a function running in RAM (Lpc21xx+GnuArm)?
2006-01-18 by Bertrik Sikken
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
arkeryd wrote:
> Hi,
> prejudicial?)
Also have a look at Martin Thomas' page, he has some example code for
the GNU toolchain at:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/#gcc_ramfunc
Bertrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFDznqeETD6mlrWxPURAuHsAJ94n4hraaxhiu52wEvy53t6PMXA7wCfaJ0p
gPbx3rCWaJRIonrOWhp/XEk=
=O7Ui
-----END PGP SIGNATURE-----
2006-01-19 by arkeryd
Thanks to all who replied!
I ended up defining a section named ram_func in the .ld file similiar
to the example from analog electronics and added "__attribute__
((section(".ram_func")));" to the headers of each function I want to
have in ram.
This works fine, and for some reason unknown for me this avoids the
compiler warnings that arrise when just declaring "__atribute__
((section(".data")));". :-)
If anybody is interested, I did the changes listed further below
compared to the default .ld file for LPC2129.
Btw, if anybody knows how to calculate the "_ramfuncetext" value
without needing to explicitly specify "- 0x40000000", I would be glad
to know how!
/ Dennis
MEMORY
  CODE (rx) : ORIGIN = 0x00000000, LENGTH = 0x0001E000
  DATA (rw) : ORIGIN = 0x40000000, LENGTH = 0x00003FE0
/* Section Definitions */
SECTIONS
  _etext = . ;
  PROVIDE (etext = .);
  /* .data section which is used for initialized data */
  .data : AT (_etext)
    _data = . ;
    *(.data)
    SORT(CONSTRUCTORS)
  } >DATA
  . = ALIGN(4);
  _foo = . ;
  _ramfuncetext = _foo - 0x40000000 + _etext;
  PROVIDE (ramfuncetext = .);
  .ram_func : AT (_ramfuncetext)
    _ram_func = .;
    *(.ram_func)
  } >DATA
  . = ALIGN(4);
2006-01-19 by wmk6341
Try this.
MEMORY
SECTIONS
  _etext = . ;
  .data : AT (_etext)
    _data = . ;
    *(.data)
    . = ALIGN(4)
    *(.ram_func)
    SORT(CONSTRUCTORS)
    } >DATA
-Bill Knight
R O SoftWare
Re: [lpc2000] Re: How to get a function running in RAM (Lpc21xx+GnuArm)?
2006-01-19 by Karl Olsen
---- Original Message ----
To: <lpc2000@yahoogroups.com>
Sent: Wednesday, January 18, 2006 5:28 PM
Subject: RE: [lpc2000] Re: How to get a function running in RAM
(Lpc21xx+GnuArm)?
> speed (barring branches).  But on other ARMs, Flash may be very slow,
> so copying to RAM is important for critical routines.
It also matters for LPC chips, not so much because of speed differences, but
because interrupt functions that can be called while the foreground program
does IAP calls to program/erase the flash, cannot be executed out of flash.
Karl Olsen
