Calling IAP-routines from thumb mode
2006-01-22 by conrado
Hi Guys,
I try to call the IAP-routines from ARM-mode with help of the code
to enter THUMB-mode from the file section:
static void callIAP(void)
// fast way to get the address of flashParams[] directly into r0
register void *pFP asm("r0") = flashParams;
asm volatile(" mov r1, r0\n" // copy &flashParams[] into
r1
" bx %[iapLocation]" // 'bx' because IAP is Thumb
mode
: "r" (pFP), [iapLocation] "r" (IAP_LOCATION)
: "r1" );
The code runs fine, the IAP is entered in thumb mode and returns to
ARM-mode again. Only nothing happens: when I try to read the Part Id
(command 0x36) it returns 0. The same for the Boot Code (command
0x37). R0 / R1 points to the (same) FlashParams. With help of the
debugger I see the 0x36/0x37-commands in these parameters are
overwritten by zero.
Who can help me please?
Thanks in advance,
Conrado
