Lpc2000
SPI and SSP double buffered?
2006-01-27 by Gus
Hello,
On SPI, is the shift register different than the data register? In
other words, if I am a slave, can I put data in the SPI data register
any time even while a transition is in progress? On PIC micros this is
safe practice but what about LPC?
Gus
Re: [lpc2000] SPI and SSP double buffered?
2006-01-27 by Mauricio Scaff
The SPI of the PICs is in my view superior of the one implemented in
LPC. In LPC the maximum clock is lower (per Main clock) and you have no
double buffering.
 From the User Manual:
/12.2.8 Write Collision
As stated previously, there is no write buffer between the SPI block bus
interface, and the internal shift register. As a result, data must not
be written to the SPI data register when a SPI data transfer is
currently in progress. The time frame where data cannot be written to
the SPI data register is from when the transfer starts, until after the
status register has been read when the SPIF status is active. If the SPI
data register is written in this time frame, the write data will be
lost, and the write collision (WCOL) bit in the status register will be
activated.
But I think that Philips knows that, because in the newer devices, one
of the SPI is a SSP. And now you have not one 1 char in the buffer, but 8.
and the maximum clock rate is higher too (from 7.5Mhz to 30Mhz).
Mauricio
Gus wrote:
> Hello,
> Thanks,
> Gus
> SPONSORED LINKS
> Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=mfaAujKZXA2Z_vxre9sGnQ>
> 	Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=9jjd2D3GOLIESVQssLmLsA>
> 	Intel microprocessors
> <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=OMnZuqMZX95mgutt4B-tDw>
> Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=Malspbd0T4Rq3M4Q0nHrfw>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
RE: [lpc2000] SPI and SSP double buffered?
2006-01-27 by Joel Winarske
SPI Data Register
User Manual excerpt:
"Writes to this register will be blocked from when a data transfer starts to
when the SPIF status bit is set, and the status register has not been read."
SSP port:
8 byte rx/tx FIFO, max speed is pclk/2.  You can fill FIFO at full speed,
refill from interrupt, or poll FIFO register for state change.
Joel
