LPC2210 external memory interface timing
2006-01-28 by smoutpatrick
I'm trying to calculate how many MIPS I could get out of a LPC2210 running at highest possible frequency using external burst mode flash memory. Somehow, I'm a bit disappointed at the moment. 1° On page 31 of the LPC2210 2220 User Manual is stated that the length of of a read access (except for subsequent reads from a burst ROM), in CCLK cycles, is the number of waitstates + 3. If I'm correct this means that even with 0 waitstate memory I need 3 clockcycles to read a word out of memory? The timing diagram on P35 confirms this behavior. 2° We are using burst mode with a 25ns page read time. In order to use burstmode, the manual tells me that Taccburst <= Tcyc - 20ns. This means that Tcyc >= (25+20)ns or CCLK <= 22.22MHz . The burst has a max. length of 4 reads, so we have 1 initial read followed by 3 fast reads. Our Initial read needs 1 waitstate (90nS) and takes 4 clockcycles. The succeeding 3 reads only take 1 clockcycle. As a result, I got 4 reads for 7 clockcycles or 12.57 MIPS @ 22MHz. Any flaws in this calculation? Thanks for the feedback, Patrick Smout
