Lpc2000
GCC compiler generates wrong code for interrupt handler routines
2006-01-31 by c.barbaro
I'm working with LCP2138 using the Keil demo board and the UVision IDE
with GNU compiler 3.3.1.
When I switched from examples to a little more complicated interrupt
handler for the UART0 I started experiencing strange problems: hangs,
reboots, function in the main program called out of order...
Giving a look to the asm listing I see that the GCC compiler insert an
extra 'sub lr, lr, #4' opcode in the isr entrypoint, and at the end of
isr uses the  'subs pc, lr, #4'
In this way the main program continues the execution not from were was
interrupted, but at an instruction before.
Here is the isr code and the partial assembler listing:
 * Interrupt service routine for UART0 device
void Uart0_isr(void)
        WORD rxnewend;
        BYTE IrqIdent;
        BYTE i, c;
        IrqIdent = U0IIR & 0x0F;
        switch(IrqIdent) {
          case 0x02: // Transmit holding register empty.
            IOSET1 = LED1;
            break;
          case 0x04: // RX Data available
            for(i=0;i<4;i++) {
              c = U0RBR;
              rxnewend = rxbufend+1;
              if(rxnewend >= RXBUFSIZE)
                rxnewend = 0;
              if(rxnewend == rxbufini) {
                // Buffer full
                ComStatus |= COM_FULL;
              else {
                rxbuffer[rxbufend] = c;
                rxbufend = rxnewend;
            ComStatus &= ~COM_EMPTY;
            IOSET1 = LED2;
            break;
          case 0x06: // RX Line status Interrupt
            IOSET1 = LED3;
            i = U0LSR;
            break;
          case 0x0C: // Character time out
            c = U0RBR;
              rxnewend = 0;
              // Buffer full
            else {
            IOSET1 = LED4;
            break;
          default:
            IOSET1 = LED8;
            break;
 241:**** /**
 242:****  * Interrupt service routine for UART0 device
 243:**** */
 244:**** void Uart0_isr(void)
 245:**** {
 459              		.loc 1 245 0
 460              		@ Interrupt Service Routine.
 461              		@ args = 0, pretend = 0, frame = 0
 462              		@ frame_needed = 0, uses_anonymous_args = 0
 463 03e4 04E04EE2 		sub	lr, lr, #4
 464 03e8 7F502DE9 		stmfd	sp!, {r0, r1, r2, r3, r4, r5, r6, ip, lr}
 465              	.LCFI8:
 248: ****
 249: ****         WORD rxnewend;
 250: ****         BYTE IrqIdent;
 251: ****         BYTE i, c;
 252: ****
 253: ****         IrqIdent = U0IIR & 0x0F;
 466              		.loc 1 253 0
 467              	.LBB6:
 468 03ec 0339A0E3 		mov	r3, #49152
 469 03f0 8E3283E2 		add	r3, r3, #-536870904
 470 03f4 0030D3E5 		ldrb	r3, [r3, #0]	@ zero_extendqisi2
 471 03f8 0F3003E2 		and	r3, r3, #15
 296: ****           default:
 297: ****             IOSET1 = LED8;
 609              		.loc 1 297 0
 610 059c 0E32A0E3 		mov	r3, #-536870912
 611 05a0 0A3983E2 		add	r3, r3, #163840
 612 05a4 143083E2 		add	r3, r3, #20
 613 05a8 0225A0E3 		mov	r2, #8388608
 614              	.L71:
 615 05ac 002083E5 		str	r2, [r3, #0]
 298: ****             break;
 299: ****         }
 300: ****
 301: ****
 302: **** }
 616              		.loc 1 302 0
 617              	.L50:
 618 05b0 7F50BDE8 		ldmfd	sp!, {r0, r1, r2, r3, r4, r5, r6, ip, lr}
 619 05b4 04F05EE2 		subs	pc, lr, #4
Note that if I slighty semplify the handler (ex. removing the for()
loop), the compiler needs to use less registers, don't save the LR
register, does not insert the sub lr,lr,#4 opcode and the code work!!
Anyone experienced similar problems and has a solution?
Thank you.
Re: [lpc2000] GCC compiler generates wrong code for interrupt handler routines
2006-01-31 by 42Bastian Schick
c.barbaro <c.barbaro@...> schrieb am Tue, 31 Jan 2006 10:47:41
-0000:
I'd suggest to write the ISR wrapper in assembler and call from
there your ISR.
This allows you also to write the ISR in thumb mode.
This is also more compatible if you ever have to switch to another
compiler and/or use an RTOS :-)
42Bastian Schick
2006-01-31 by Richard Duits
I had the same problem and it disappeared when I disabled the "Support
Calls between ARM and THUMB Instruction Set" option.
If you use THUMB code, you can place the interrupts in a separate source
file. If you use THUMB code in your interrupts, then you should write a
wrapper function in assembler.
Richard.
c.barbaro wrote:
> Hi,
>         WORD rxnewend;
>         BYTE IrqIdent;
>         BYTE i, c;
>         switch(IrqIdent) {
>             IOSET1 = LED1;
>             break;
>             for(i=0;i<4;i++) {
>               c = U0RBR;
>                 rxnewend = 0;
>                 // Buffer full
>               else {
>             IOSET1 = LED2;
>             break;
>             IOSET1 = LED3;
>             i = U0LSR;
>             break;
>             c = U0RBR;
>               rxnewend = 0;
>               // Buffer full
>             else {
>             IOSET1 = LED4;
>             break;
>           default:
>             IOSET1 = LED8;
>             break;
> 241:**** /**
> 243:**** */
> 245:**** {
> 459                          .loc 1 245 0
> r6, ip, lr}
> 465                    .LCFI8:
> 248: ****
> 252: ****
> 466                          .loc 1 253 0
> 467                    .LBB6:
> zero_extendqisi2
> 296: ****           default:
> 609                          .loc 1 297 0
> 614                    .L71:
> 298: ****             break;
> 299: ****         }
> 300: ****
> 301: ****
> 302: **** }
> 616                          .loc 1 302 0
> 617                    .L50:
> r6, ip, lr}
> Thank you.
> SPONSORED LINKS
> Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=mfaAujKZXA2Z_vxre9sGnQ>
> 	Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=9jjd2D3GOLIESVQssLmLsA>
> 	Intel microprocessors
> <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=OMnZuqMZX95mgutt4B-tDw>
> Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=Malspbd0T4Rq3M4Q0nHrfw>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Re: GCC compiler generates wrong code for interrupt handler routines
2006-01-31 by unity0724
Hi, Experienced similar problem before.
Got it fixed with moving all local variables to global variables.
(I also kept every C statement in the ISR to be simple, such that
it does not create own local variables on stack)
I think ver GCC 3.4 and onwards has that bug fixed.
--- In lpc2000@yahoogroups.com, "c.barbaro" <c.barbaro@4...> wrote:
> Hi,
IDE
interrupt
hangs,
insert an
end of
was
>         WORD rxnewend;
>         BYTE IrqIdent;
>         BYTE i, c;
>         switch(IrqIdent) {
>             IOSET1 = LED1;
>             break;
>             for(i=0;i<4;i++) {
>               c = U0RBR;
>                 rxnewend = 0;
>                 // Buffer full
>               else {
>             IOSET1 = LED2;
>             break;
>             IOSET1 = LED3;
>             i = U0LSR;
>             break;
>             c = U0RBR;
>               rxnewend = 0;
>               // Buffer full
>             else {
>             IOSET1 = LED4;
>             break;
>           default:
>             IOSET1 = LED8;
>             break;
>  241:**** /**
>  243:**** */
>  245:**** {
>  459              		.loc 1 245 0
r5, r6, ip, lr}
>  465              	.LCFI8:
>  248: ****
>  252: ****
>  466              		.loc 1 253 0
>  467              	.LBB6:
zero_extendqisi2
>  296: ****           default:
>  609              		.loc 1 297 0
>  614              	.L71:
>  298: ****             break;
>  299: ****         }
>  300: ****
>  301: ****
>  302: **** }
>  616              		.loc 1 302 0
>  617              	.L50:
r5, r6, ip, lr}
work!!
> Thank you.
2006-01-31 by Karl Olsen
That is right.  GCC 3.3.x and older generated incorrect entry/exit code
for IRQ and FIQ handlers.  Use 3.4.x or newer.
Karl Olsen
Thank you, I'll follow the suggestion since in the near future I want
to use nested interrupts that requires an asm wrapper anyway.
For now I patched the problem using an ISR that performs a call to the
real one that contains the code I need.
--- In lpc2000@yahoogroups.com, 42Bastian Schick <bastian42@m...> wrote:
> c.barbaro <c.barbaro@4...> schrieb am Tue, 31 Jan 2006 10:47:41
> -0000:
> there your ISR.
> 42Bastian Schick
Thank you, I'll upgrade as soon as is possible even I I'll have to
renounce to the Keil uVision IDE.
Someone told me that is compatible only with GCC 3.3.1
Carlo Barbaro
> Karl Olsen
Re: [lpc2000] Re: GCC compiler generates wrong code for interrupt handler routines
Take a look at the following link:
http://www.keil.com/support/docs/3127.htm
Keil directed me to this page when I asked if I could use other GCC
binaries. I did not try it myself yet.
Richard.
> Carlo Barbaro
> > Karl Olsen
> SPONSORED LINKS
> Microcontrollers
> 	Microprocessor
> YAHOO! GROUPS LINKS
2006-01-31 by Tom Walsh
Definately get away from using Thumb code with gcc-3.4.x.  There is some
documented problems, under certain conditions, that  when an interrupt
occurs during a Thumb function execution it can corrupt the stack.  This
stack corruption was noted in gcc-3.3.x and was finally resolved in
gcc-4.0.x.
I'm currently using gcc-4.0.2 and the thumb code is running fine under
heavy interrupt usage.
TomW
BTW, I'm not using the Keil thingy.
2006-01-31 by 3gpabko
I am also using GCC v3.3.1 integrated in Ashling IDE
and I don't have problems with the code generated for
ISR.
You should use:
__attribute__ ((interrupt("IRQ")))
or
__attribute__ ((interrupt("FIQ")))
for your ISR's.
Zdravko Dimitrov
--- "c.barbaro" <c.barbaro@...> wrote:
> Hi,
> and the UVision IDE
> problems: hangs,
> order...
> compiler insert an
> and at the end of
> not from were was
> listing:
>         WORD rxnewend;
>         BYTE IrqIdent;
>         BYTE i, c;
>         switch(IrqIdent) {
> empty.
>             IOSET1 = LED1;
>             break;
>             for(i=0;i<4;i++) {
>               c = U0RBR;
>                 rxnewend = 0;
>                 // Buffer full
>               else {
>             IOSET1 = LED2;
>             break;
>             IOSET1 = LED3;
>             i = U0LSR;
>             break;
>             c = U0RBR;
>               rxnewend = 0;
>               // Buffer full
>             else {
>             IOSET1 = LED4;
>             break;
>           default:
>             IOSET1 = LED8;
>             break;
>  241:**** /**
> device
>  243:**** */
>  245:**** {
>  459              		.loc 1 245 0
> 0
> r5, r6, ip, lr}
>  465              	.LCFI8:
>  248: ****
>  252: ****
>  466              		.loc 1 253 0
>  467              	.LBB6:
> zero_extendqisi2
>  296: ****           default:
>  609              		.loc 1 297 0
>  614              	.L71:
>  298: ****             break;
>  299: ****         }
>  300: ****
>  301: ****
>  302: **** }
>  616              		.loc 1 302 0
>  617              	.L50:
> r5, r6, ip, lr}
> removing the for()
> don't save the LR
> and the code work!!
> solution?
> Thank you.
Do You Yahoo!?
http://mail.yahoo.com
