I found the problem. The DC supply had a false start. For the 500mS
or so before it would ramp-up to 3.3V, it would wobble around .5-
1V. This was due to leakage through a 232 driver as well as an
idosyncracy of the DC supply. During the wobble, Reset was hard
low, so I'm suprised the voltage on Vcc mattered. Putting a 1k pull-
down on the 3.3V to ensure when the 3.3V is OFF, the Vcc of the
LPC2132 goes to all the way to ground, fixed the problem.
Live and learn.
--- In lpc2000@yahoogroups.com, Rock Raj <rockraj_2003@...> wrote:
> Hi John,
> Had u pulled the P0.14 PIN TO LOW.
> Since u connected a 10k pull up, just check the pin with a
multimeter.
> Provide the Power Supply as per in the User Manual.
> or try by inserting external switch on reset.
> I had the same problem in LPC2138. I connected only a 10k pullup
to the P0.14 Pin and a i grounded via a jumper. Then in the reset
pin i used the same 10k pull up with an external reset switch it
worked properly.
> U can see the schematic files in the LPC groups.
> cheers,
> Rajender
> johnsonnenberg99 <johnsonnenberg99@...> wrote:
> My LPC2132 fails to start running about 1/100 power-ups. 99 out
of
> 100, everything is OK.
> The Symptoms when if fails:
> a) Crystal does not oscillate. No voltage on either crystal osc
> pin.
> b) No firmware appears to ever run or initialize anythign in my
> hardware.
> c)I/O pins are still inputs.
> d)P0.14 is pulled low by CPU (I have a 10K P/U on it). This
> symptom baffles me.
> When it is broke, I tried asserting reset low manually. It does
not
> clear the condition. P0.14 stays stuck low, even with a manual
> reset. (power stays on through the reset. )
> I have checked the usual issues (P0.31 is pulled-up w/10K, P0.14
is
> pulled up w/10K, P1.20 is pulled up w/4.7K, PU on all JTAG lines
> except 10K PD on TCK)
> I've got a number of boaords doing this. Power on, reset was
> assered properly, but XTAL does not start. CPU appears to be
> dead. Any ideas would be much appreciated.
> Some I/O pins go to circuits that have zigh-z (>1Mohm) paths to
5V,
> and the 5V does come up before the 3.3. Could this be it?
> Thanks in advance for any comments.
> John
> SPONSORED LINKS
> Microcontrollers Microprocessor Intel
microprocessors Pic microcontrollers
> YAHOO! GROUPS LINKS
> Visit your group "lpc2000" on the web.
> To unsubscribe from this group, send an email to:
> lpc2000-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
> Jiyo cricket on Yahoo! India cricket
