Lpc2000
ADC on LPC2134 vs. ADC on LPC2138
2006-02-06 by gaquaycalifornia
Please help with the Adcs.
I having problem of reading conversion from ADC_1.
LPC2134/6/8 have two ADCs and 16 pins to connect to.
I wrote the following code. and it runs fine in the evaluation board
LPC2138, but not the target board LPC2134.
Here is what I did.
Initialize ADC0
Initialize ADC1
Both has interrupt vectors assigned to.
#define configure_adc_0 0x01215F00
#define configure_adc_1 0x01215F00
void adc_0_initialize (int * p, int lastchannel)
	index_0 = 0;
	memcpy(&x[0], p,32);
	lastchannel_adc_0 = lastchannel;
	VICVectAddr3 = (unsigned long)adc0_irq;
	VICVectCntl3 = 0x32;
	VICIntEnable |= VIC_BIT(VIC_ADC_0);
	AD0CR   = configure_adc_0 | Find_Next_Channel(lastchannel,0) ;
void adc_1_initialize (int * p, int lastchannel)
	index_1 = 0;
	memcpy(&y[0], p,32);
	lastchannel_adc_1 = lastchannel;
	VICVectAddr10 = (unsigned long)adc1_irq;
	VICVectCntl10 = 0x35;
	VICIntEnable |= VIC_BIT(VIC_ADC_1);
	AD1CR   = configure_adc_1 | Find_Next_Channel(lastchannel,1) ;
// to start both ADCs
void StartAdcs(void){
	ADGSR = 0x01010000;
// isr of adc0
void adc0_irq (void) __irq
	int chan, tmp;
	unsigned short val;
	tmp = AD0DR;
	chan = ((tmp >> 24)& 0x07);
	val =  (unsigned short)((tmp >> 6 )& 0x3FF);
	result_0[index_0][chan] = val;
	index_0 = IncrementInindex(index_0,chan,0);
	AD0CR  = configure_adc_0 | Find_Next_Channel(chan,0) ;
	VICVectAddr = 0;
// isr of adc1
void adc1_irq (void) __irq
	int chan, tmp;
	unsigned short val;
	tmp = AD1DR;
	result_1[index_1][chan] = val;
	index_1 = IncrementInindex(index_1,chan,1);
	AD1CR   = configure_adc_1 | Find_Next_Channel(chan,1) ;
	VICVectAddr = 0;
On the evaluation board which has LPC2138 it runs fine, both
interrupt got triggered.
When move this code onto the target with a LPC2134, only adc0 gets
triggerd.
Please take a look and help me with any ideas
thanks
Re: ADC on LPC2134 vs. ADC on LPC2138
2006-02-06 by brendanmurphy37
Have you looked at the peripheral power-control register (PCONP)
setting?
We had a similar problem a while back (see message 8441). It turned
out this had to be set explicitely to enable teh 2nd ADC: the
maunual's description of the default setting turned out to be wrong.
Brendan
--- In lpc2000@yahoogroups.com, "gaquaycalifornia"
<gaquaycalifornia@...> wrote:
> Hi,
board
> Here is what I did.
> Initialize ADC0
> Initialize ADC1
> 	index_0 = 0;
> 	index_1 = 0;
> 	ADGSR = 0x01010000;
> // isr of adc0
> 	int chan, tmp;
> 	unsigned short val;
> 	tmp = AD0DR;
> 	VICVectAddr = 0;
> // isr of adc1
> 	int chan, tmp;
> 	unsigned short val;
> 	tmp = AD1DR;
> 	VICVectAddr = 0;
> triggerd.
> thanks
Re: [lpc2000] Re: ADC on LPC2134 vs. ADC on LPC2138
2006-02-10 by Tong Le
Thanks for the help.
  Just what it takes to make it works
  thanks
setting?
Brendan
> Hi,
board
> Here is what I did.
> Initialize ADC0
> Initialize ADC1
>       index_0 = 0;
>       index_1 = 0;
>       ADGSR = 0x01010000;
> // isr of adc0
>       int chan, tmp;
>       unsigned short val;
>       tmp = AD0DR;
>       VICVectAddr = 0;
> // isr of adc1
>       int chan, tmp;
>       unsigned short val;
>       tmp = AD1DR;
>       VICVectAddr = 0;
> triggerd.
> thanks
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors     Pic microcontrollers
  YAHOO! GROUPS LINKS
 Yahoo! Autos. Looking for a sweet ride? Get pricing, reviews, & more on new and used cars.
