AW: [lpc2000] Re: Rise and fall time of capture inputs
2006-02-06 by Huber Martin
________________________________ Von: Karl Olsen [mailto:kro@...] Gesendet: Montag, 6. Februar 2006 10:30 An: lpc2000@yahoogroups.com Betreff: [lpc2000] Re: Rise and fall time of capture inputs I don't think it is possible to miss a capture event because of slow rise/fall times. You get a capture event when the input is e.g. low at one pclk edge and high at the next, and this will happen at least once no matter how slow the input rises. [MEH] This is an interesting fact. Thank you. Another problem might be noise on the input so that you get multiple rise and fall events around the switching level. The datasheets say that there is a hysteresis of typically 0.4V on all standard port pins and some more on the I2C pins, so this should filter most noise. [MEH] That's the reason my signal is so slow. It's filtered with an EMI-Filter, so no flicker should be on the line. Karl Olsen SPONSORED LINKS Microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontroller s&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4 &s=95&.sig=mfaAujKZXA2Z_vxre9sGnQ> Microprocessor <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers& w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s =95&.sig=9jjd2D3GOLIESVQssLmLsA> Intel microprocessors <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontr ollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontroller s&c=4&s=95&.sig=OMnZuqMZX95mgutt4B-tDw> Pic microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontro llers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers &c=4&s=95&.sig=Malspbd0T4Rq3M4Q0nHrfw> ________________________________ YAHOO! GROUPS LINKS * Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> " on the web. * To unsubscribe from this group, send an email to: lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . ________________________________ [Non-text portions of this message have been removed]
