Re: Efsl-devel digest, Vol 1 #33 - 1 msg
2006-02-08 by Steve Franks
Yea Efsl! I downloaded, read the manual, compiled on GCC for arm and tested inside an hour, no problems. That's what I call smooth code. Efsl tested on IAR/Olimex LPC2148 Kickstart board built with current GCC-Arm (4.0.2) and old SanDisk 32MB SD with FAT16; status: no problems encountered. Only edits were to rename LPC2138-ROM.ld to LPC2148-ROM.ld, change processor from lpc2138 to lpc2148 in makefile, and rename lpc-config.h to config.h. Steve
2006-02-15 by Jim Parziale
On 2/8/06, Steve Franks <stevefranks@...> wrote: > > Yea Efsl! I downloaded, read the manual, compiled on GCC for arm and > tested inside an hour, no problems. That's what I call smooth code. > > Efsl tested on IAR/Olimex LPC2148 Kickstart board built with current > GCC-Arm (4.0.2) and old SanDisk 32MB SD with FAT16; status: no > problems encountered. Only edits were to rename LPC2138-ROM.ld to > LPC2148-ROM.ld, change processor from lpc2138 to lpc2148 in makefile, > and rename lpc-config.h to config.h. > > Steve > > Sounds excellent! Just for info, which version are you using? Latest stable = 0.2.6 Latest development = 0.3.5 They seem to be very different from each other. -- Jim Parziale nuncio.bitis@... Malden, MA [Non-text portions of this message have been removed]
2006-02-16 by Steve Franks
Re Efsl: I was using the stable branch. There was a warning somewhere that the devel branch was not for use and some things were unimplemented. Steve
2006-04-16 by darcyw@satlan.co.nz
> Yea Efsl! I downloaded, read the manual, compiled on GCC for arm and >tested inside an hour, no problems. That's what I call smooth code. > >Efsl tested on IAR/Olimex LPC2148 Kickstart board built with current >GCC-Arm (4.0.2) and old SanDisk 32MB SD with FAT16; status: no >problems encountered. Only edits were to rename LPC2138-ROM.ld to >LPC2148-ROM.ld, change processor from lpc2138 to lpc2148 in makefile, >and rename lpc-config.h to config.h. > >Steve Hi Steve, Could you please post this somewhere for newbies such as myself to get a better understanding of how this all works? :) I've used IDEs for so many years and am now trying to use GCC but have very little understanding of makefiles. I've tried porting EFSL over but just end up with so many make errors I give up in frustration. Kind Regards Darcy
2006-04-16 by rtstofer
--- In lpc2000@yahoogroups.com, darcyw@... wrote: > > > Yea Efsl! I downloaded, read the manual, compiled on GCC for arm and > >tested inside an hour, no problems. That's what I call smooth code. > > > >Efsl tested on IAR/Olimex LPC2148 Kickstart board built with current > >GCC-Arm (4.0.2) and old SanDisk 32MB SD with FAT16; status: no > >problems encountered. Only edits were to rename LPC2138-ROM.ld to > >LPC2148-ROM.ld, change processor from lpc2138 to lpc2148 in makefile, > >and rename lpc-config.h to config.h. > > > >Steve > > Hi Steve, > > Could you please post this somewhere for newbies such as myself to get a better understanding of how this all works? :) I've used IDEs for so many years and am now trying to use GCC but have very little understanding of makefiles. I've tried porting EFSL over but just end up with so many make errors I give up in frustration. > > Kind Regards > Darcy > Just for fun, I downloaded EFSL and compiled it to create an AVR library and an ARM library using the respective GNU toolchains. No warnings or errors. The instructions for the AVR target apply to the LPC target where no build instructions are given. The only real issue is creating config.h from one of the prototypes in the 'conf' directory. Download the file to a directory, say ~/EFSL. Then: [rstofer@DellPWS EFSL]$ ls efsl-0.2.7.tar.bz2 manual-0.2.7.pdf <= source files and manual [rstofer@DellPWS EFSL]$ bunzip2 efsl-0.2.7.tar.bz2 [rstofer@DellPWS EFSL]$ tar -xvf efsl-0.2.7.tar ... tar output omitted ... [rstofer@DellPWS EFSL]$ ls efsl-0.2.7 efsl-0.2.7.tar manual-0.2.7.pdf <= efsl directory created [rstofer@DellPWS EFSL]$ cd efsl-0.2.7/conf [rstofer@DellPWS conf]$ ls config-sample-avr.h config-sample-lpc2000.h config-sample-linux.h config-sample-nios2.h [rstofer@DellPWS conf]$ cp config-sample-lpc2000.h config.h [rstofer@DellPWS conf]$ cd .. [rstofer@DellPWS efsl-0.2.7]$ ls conf examples linuxutils Makefile-LINUX src docs inc Makefile-AVR Makefile-LPC2000 testfiles [rstofer@DellPWS efsl-0.2.7]$ make -f Makefile-LPC2000 ... compiler output omitted -- no errors, no warnings ... [rstofer@DellPWS efsl-0.2.7]$ ls conf examples libefsl.a Makefile-AVR Makefile-LPC2000 testfiles docs inc linuxutils Makefile-LINUX src [rstofer@DellPWS efsl-0.2.7]$ libefsl.a (the efsl library) was created. Richard
