Lpc2000
Help for GNUARM 4.0.2 Cygwin installation.
2006-02-15 by c.barbaro
I'm working with Keil uVision environment using the gcc 3.3.1 compiler
and now I want to switch to gcc 4.0.2 so I downloaded the gnuarm
toolchain for cygwin from the www.gnuarm.org.
With the Keil environment the gnu toolchain was installed in the
c:\cygnus directory of my PC and the path was set for
c:\cygnus\arm-tools\bin;c:\cygnus\bin
I removed the old path, renamed the cygnus directory before installing
the new toolchain.
The installer for the gcc 4.0.2 toolchain created the
c:\Programs\gnuarm directory, put the cygwin dll's in
c:\Programs\gnuarm\bin directory together to the gcc exe tools, and
finally set the path to that directory.
The problem is that opening a command line window (my PC runs
Windows2000) and typing arm-elf-gcc nothing occur: simply a new
command line prompt is displayed.
For other tools all is ok: for example typing arm-elf-ar I get the
help screen for that command.
I'm a newbie but what I'm doing wrong?
Thank you for your help.
Re: Help for GNUARM 4.0.2 Cygwin installation.
2006-02-15 by ntfreak2000
Keil gcc does not use the same toolchain as GNUARM, they do use gcc
but they use uclibc rather than newlib as the c library.
They will call arm-uclibc-gcc rather than arm-elf-gcc
While you are learning i would recommend you stick with the standard
installation - you will have enough to learn.
Spen
compiler
installing
> the new toolchain.
2006-02-16 by c.barbaro
Unfortunatly I'm not just learning, I'm involved in a "real" project
in my company.
I'm switching to gcc 4.0.2 to avoid the problem that 3.3.1 compiler
creates compiling interrupt handler code.
However I solved my problem: the gnuarm package is missing the
cygintl-3.dll: downloading apart and putting it in the bin directory
makes the gcc works.
(WinXP generated the missing dll error, Win2K no!)
Compiling my code with newlib instead of uclibc should not make a
great difference for my code since I don't use printf, malloc,
floating point, and so on...
Thank you,
Carlo
> Regards
> Spen
> compiler
> installing
> > the new toolchain.
Re: [lpc2000] Re: Help for GNUARM 4.0.2 Cygwin installation.
2006-02-16 by Tom Walsh
>in my company.
>Thank you,
>Carlo
Gee, I wouldn't use Windows for the host of a "real project".  Not that
I am an operating system bigot, I'd run MSDOS and Windows for many
years, my last purchased Windows was WinNt-4.  During the past 6 years
I've moved away from Windows platforms for doing embedded software (and
other software) development.  The bottom line has been the lack of tools
and reliability, notably that when something went wrong it was difficult
to find out just what it was that broke.  Another issue was the cost,
every time I turned around I was spending nickels & dimes for software
to do things that a "real" operating system should have had.  Those
nickels & dimes kept adding up.
Having said all this, why not check a out a decent linux distro and see
if that will do what you need?  After all, cygwin is an attempt at
imitating the very environment that is Linux!  Linux distros have come a
huge distance in the past few years, I regularly use Mandriva (currently
Mandriva-2006) and I find it difficult to believe that a Windows user
would find themselves completely at a loss when sitting at a Mandriva
distro.
There is the problem of cost, there is no wiggler for Linux, nor is
there a suitable USB JTAG debugger (maybe USB == cheap JTAG).  But if
you are doing a "real project", then a good tools mentality would
completely disqualify a wiggler?  I use an ethernet based JTAG and gdb
connects to it just fine (Abatron BDI2000).  The BDI2000 is expensive,
but it does more than just one processor, or processor family.  It is a
peice of equipment, and an investment, such as a good 300MHz scope, or
digitial multimeter would be.
Not for nothing, but is it worth the aggravation of doing development on
a Windows host?  I've found that I can get so much more done with a
Makefile than a project file.  Editing source files is so much faster to
do with a simple, but powerful, editor such as vi (vim) as opposed to
mouse driven editors.  Tools such as perl, grep, sed, xargs, etc. are
just "in there" when it comes to a Linux environ while you either have
to purchase them or install into a work-alike such as cygwin.
I've supported an older 8bit product for many years using an MSDOS based
compiler (Archemedes 8051 C compiler / Assembler).  Over the past 5
years, I've gradually moved that product development over to Linux.  The
file editing went first, then the compiler (via dosemu), and finally the
source went into cvs.  Each step of the way I've experience a large
productivity increase!  I do things with the makefile such as building,
then running, test software which validates my data structures (binary
search arrays).
Support for GNU development tools is still largely from un*x people.
I'm not aware of a large number of people using cygwin to do
development.  But then, it may be that I happen to be on IRC channels in
which only un*x people hang out?
I write code for a living, I strongly encourage fellow coders to check
out Linux!
Respectfully,
TomW
>>Regards
>>Spen
>>compiler
>>installing
>>>the new toolchain.
>Yahoo! Groups Links
