MCB2130 on-board Flash
2006-02-20 by hayamu1994
Followings are the environment we're working on: CPU: ARM7TDMI-S (LPC2138 provided by Philips) Board: MCB2130 (by Keil) Development tool: ADS1.2 ICE: Multi-ICE Although a sample code is used for its boot processing, the board doesn't appear to start appropriately. And I cannot define the problem due to luck of my experience. I assume it's because the allocation to Flash and RAM has not been done correctly while trying to do the mapping using scatter-loading file. What I have learned from the spec document is that the settings of re-mapping and entry point need to be done appropriately, and I keep doing trial and error to figure out its correct setting for LPC2138. However, due to lack of my experience, it's not been successful so far. Any advice or information that might be our help would be really appreciated. Best regards,
