Lpc2000
How to generate Freq & how to perform bit operation
2006-02-21 by Saravanakumar S
Hi  ,
        I am new to this Embedded field.
        I have the following query.
                1.I want to generate Particular frequency Say Eg 50 kHz,
with enable Ack bit.
                        When ever i want to generate the frequency,then i
will enable the Ack bit.if i disable the bit means it will not generate
the frequency.
        I have the perplextion,how can i achieve this problem?. There are
3 ways to sortout this problem.
                                1.With out using timer & PWM only using
GPIO functionality.
                                2.Using timer as a VIC interrupt
                                3.Using timer as a Match register
        If anybody having some other idea,can you suggest me? which one is
best?
        I  am using LPC 2106 microcontroller.How can i perform bit
operation.Bcoz if you want to perform bit operation in 8051
microcontroller ,it is very easy.
        The Same operation, i want to perform in LPC 2106 microcontroller.
                                IOSET=0x00000001
                                IOCLR=0x00000001
        We have to send the data like this,for each & every time.Otherwise
some other way is there to perform bit operation.
S.kumar
