Lpc2000
LPC214X UART 5V tolerance
2006-02-21 by deliconn
I know the I/O pins are 5V tolerant, does that also mean that the
other devices connected to them are also 5V tolerant?  I want to use a
5V RS232 transceiver instead of a 3.3V one.  The 5V transceivers are
much cheaper than the 3.3V ones.
Vern
Re: [lpc2000] LPC214X UART 5V tolerance
2006-02-21 by Xtian Xultz
Em Ter 21 Fev 2006 15:13, deliconn escreveu:
> Thanks,
> Vern
I am using here a MAX232 attached to a LPC2106. The MAX232 runs at 5V and I
founded no problems, the 3.3V from the LPC TX is enough to run the MAX232 and
the 5V RX from MAX232 causes no problem in the LPC. I tryed some speeds, but
now I am working at 115200. I did ISP too, without problems.
I tryed also 75176 to run RS485 at 5V, and worked fine too.
