Lpc2000
IAP throwing Undefined Instruction on some units
2006-02-23 by sig5534
CPU: LPC2104
Compiler: GCCARM
This is a really strange problem.  I am using IAP on some of my
internal routines, my code was basically done for sometime now.
Everything was working.  I built somemore proto boards and now a
problem has shown up on 2 out of 11 boards.
When the IAP call executes to do a CopyRamToFlash, the CPU locks up
going into the UIE vector (Undefined Instruction Exception). I ran a
trace over and over again and the flash parameters are all setup
right, but after the jump up into the high mem builtin IAP handler,
it locks up the CPU at the UIE vector (0x38).  It never comes back
from the IAP(CopyRamToFlash) call.
I can't understand this.  On 9 of the boards it works but on these 2
it does not.  Same problem on both.  I have a 24MHz xtal and PLL set
to 48Mhz.  I have tried calling the IAP() routine using either 24 or
48 MHz but it makes no difference.  The built in IAP routine is going
into the weeds, but only on some units.
Everything else on the PCBs is working normally, and the CPU is
executing the rest of the code fine.  It is just that IAP() routine
that is going nuts, and only on the CopyRamToFlash function.  The
other calls like IAP erase sectors etc. are fine.
Other than the flashparameters, I do not see much else I can do to
control the situation.  The IAP routine goes into the weeds on some
LC2104 units but not on others.  Same code.  Really strange.  About
the only thing I see left to do is change the CPUs.  Yet they take
programming up the UART0 port.  Bizarre.
Anyone have any ideas on this?
Thanks,  Chris.
Re: [lpc2000] IAP throwing Undefined Instruction on some units
2006-02-23 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Thursday, February 23, 2006 4:56 AM
Subject: [lpc2000] IAP throwing Undefined Instruction on some units
> CPU: LPC2104
> Compiler: GCCARM
What silicon revision?
Leon
Re: IAP throwing Undefined Instruction on some units
> Leon
It says 1.3  I guess that is the problem.  I see now that there is a
BIG errata info on this whole problem.  I just downloaded the stuff on
the bootloader update to 1.52.  This sure sounds like the problem I am
seeing.  I'll try it tomorrow.  In fact I did further testing and found
that the same chip/board would sometimes pass and then fail IAP calls.
So this is indeed a flaky problem.
From what I see on updating the boot loader, it appears to be a bit of
a procedure.  Not a fun prospect for updating 100 units we have
arriving for the first production run.
I also see in the Errata a bunch of info on the SPI problems I saw last
year.  I guess I know now I wasn't crazy after all.  Philips had quite
a few bugs in these critters.
Thanks,  Chris.
2006-02-23 by Danish Ali
I think your crystal is faster than most of us use, so you might
be in uncharted territory.
Is it possible that you're giving the IAP call the wrong value for
the system clock frequency? The time of the flash write might be
process-dependent (and temperature and supply-voltage) so it
might vary from chip to chip. If the processor returns before
the flash is ready, who knows what instruction will be fetched.
Param3 should be 24000 or 48000 because it is in kHz.
Try boosting it by 20% to see if it is an extreme process corner.
(It is possible that such numbers are outside the range Philips
tested in their IAP delay routines. But the data sheet says
it should cope with up to 25000 kHz).
Another thing I would try is a longer delay between
"prepare for write" and "copy ram to flash".
ISP programming is likely to have a long delay between commands.
Hope this helps you get these chips working,
Danish
Re: [lpc2000] Re: IAP throwing Undefined Instruction on some units
2006-02-23 by sig5534@hotmail.com
I think the other guys hit the problem.  Philips has bugs in the old 1.3 version boot loader.  I will try updating the boot loaders tomorrow to 1.52.  The info in the errata PDF is exactly what I am seeing, and it happens at higher clk rates which is exactly what I have.  Actually quite a few bugs in these parts. I've run into other bugs last year that I now see documented in the PDF of Nov-2005.
Thanks,  Chris.
  To: lpc2000@yahoogroups.com
  Sent: Thursday, February 23, 2006 12:58 AM
  Subject: [lpc2000] Re: IAP throwing Undefined Instruction on some units
  Danish
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
        Pic microcontrollers
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2006-02-25 by sig5534@hotmail.com
If you are curious.  That was the problem.  All of the boards are working now.
Chris.
  Sent: Thursday, February 23, 2006 1:05 AM
  Subject: Re: [lpc2000] Re: IAP throwing Undefined Instruction on some units
  Thanks,  Chris.
    Danish
    YAHOO! GROUPS LINKS
  YAHOO! GROUPS LINKS
