Lpc2000
UART0 and UART1 baud rate calculations
2006-02-23 by dodge1955
Has anyone ever done some type of spreadsheet on the different UxDLL
and UxDLM values along with MULVAL and DIVVAL for the most popular
crystals to make the baud rate come out perfect (like 9600, 19200,
etc).  The manual has the examples for 20Mhz, but it would be nice to
have some appendix that has a table of values that come out even for a
variety of commonly used crystals.  11.059Mhz is obviously an easy
one, but others like 12Mhz, 15Mhz, etc. are not as easy and I know
some crystals may not have a perfect value and thus have an error factor.
Sutton - dodge55
RE: [lpc2000] UART0 and UART1 baud rate calculations
2006-02-23 by Joel Winarske
Hi Sutton,
I wrote this utility for the fractional divide enabled UART parts.  It
prints out % error from lowest to highest.  It's not useful for non-fdr
enabled parts.  I'll update in the next week or so for fractional divider
challenged parts.  Perhaps I'll make it a Win32 app as well.
http://groups.yahoo.com/group/lpc2000/files/Tools/lpc2fdcalc.exe
Joel
Re: [lpc2000] UART0 and UART1 baud rate calculations
2006-02-24 by Bill Knight
Crystals that are integer multiples of 1.8432MHz can be used to create
BAUD rates with 0% error.  High/low values for the part & PLL obviously
must be observed.
-Bill Knight
R O SoftWare
>Sutton - dodge55
>Yahoo! Groups Links
2006-02-25 by Tom Walsh
>Sutton - dodge55
I did a perl script just to calculate errors of the LPC2106 & LPC2138
processors based on crystal frequency:
=============== begin baudrates.pl ==================
#!/usr/bin/perl
# this determines the degree of error between desired and actual
# baudrates on the LPC21xx processors.
my $FREQ = 14745000;
my $PLL_MUL = 4;
my $PBSD = 2;
my $CCLK = ($FREQ * $PLL_MUL);
my $PCLK = ($CCLK / $PBSD);
#my $PCLK = 20000000;
my @commonRates =
(300,600,1200,2400,4800,9600,19200,38400,57600,115200,230400);
#define UART_BAUD(baud) (uint16_t)((PCLK / ((baud) * 16.0)) + 0.5)
sub calcBaud {
my $desired = $_[0];
my $divisor = int(($PCLK / ($desired*16.0))+ 0.5);
my $actual = int(($PCLK / (16*$divisor)) * 1000) / 1000;
my $error = int((($actual - $desired) / $desired) * 1000000) / 10000;
   print "divisor: ${divisor}  desired: ${desired}  ".
      "actual: ${actual}  error: ${error}%\n";
   while (@commonRates) {
      calcBaud (shift(@commonRates));
================== snip =======================
Joel Winarske wrote:
>Hi Sutton,
Why?  Why not make it a perl app and then everyone can use it?
TomW
2006-02-25 by Joel Winarske
Hi Tom,
How about as a java swing applet hosted in a web page instead?  Sort of a
spreadsheet style that you can copy data from.  Then anyone with a web
browser can use it.  I am referring to fractional divide calculations.
Joel
>Hi Tom,
Webpage would probably make it more useful than a EXE file.  I do have
Windows NT running inside VMWare so I can run a couple of apps, but that
is it.
I was just pointing out that not everyone has Windows on a machine and
that some of that do don't the latest & greatest (TM - Microsoft).
TomW
>Joel
>Yahoo! Groups Links
Re: UART0 and UART1 baud rate calculations
2006-02-26 by roger_lynx
Hi Sutton,
You might want to look at this LPC214x FractCalc I put together with a
PLL calculator, PDF and ASCII viewers.
It is a Win GUI applet; subject to continuous improvements, but usable.
Check the bottom of this page:
http://www.rogerlynx.com/html/support.html
<http://www.rogerlynx.com/html/support.html>
Hope this helps.
Roger
factor.
> Sutton - dodge55
2006-02-26 by kathy_wright_ca
I like simple solutions, and I have an Excel solution that also makes
it easy to see what's going on, and it includes accuracy
calculations.
I can email to you if you like
Kathy Wright
UxDLL
nice to
for a
> factor.
> > Sutton - dodge55
Re: [lpc2000] Re: UART0 and UART1 baud rate calculations
2006-02-26 by Branko Karaklajic
Hello everyone,
I successfully booted uClinux on LPC2292 with external 4MB flash and
4MB RAM!
But I started kernel only when I load image and romfs with JTAG to RAM
and then start it from that address.
Now I must wrote bootloader. I have functions for initialization of
external memory interfaces, loading images from flash to ram, and that
is OK, but when I want to JUMP to start address of kernel... board
reboots... This is part for jumping to kernel...
---CODE---
void kernel_jump()
     void (*kernelstart)(void);
     //KERNEL_START=0x81008000;
     kernelstart = (void (*)(void))KERNEL_START;
     (*kernelstart)();
-END CODE-
Anyone have idea what is wrong, or some code sample to jump to start
of kernel..., can be in assembler...
thank you in advance
Branko Karaklajic
Best regards
Problem on starting uClinux on LPC2292...
Hello everyone,
this is REPOST because of wrong subject on earlier message. I didn't
want to hijack tread... sorry
4MB RAM!
---CODE---
void kernel_jump()
     (*kernelstart)();
-END CODE-
of kernel...
Branko Karaklajic
Best regards,
 orpid.co.yu
Re: [lpc2000] Problem on starting uClinux on LPC2292...
2006-02-26 by Bertrik Sikken
Branko Karaklajic wrote:
> Hello everyone,
> 4MB RAM!
> ---CODE---
> void kernel_jump()
>      (*kernelstart)();
> -END CODE-
> of kernel...
I think it's not needed to dereference kernelstart.
Try invoking kernelstart simply as follows:
kernelstart();
Can you follow where it is going when doing this call with the
JTAG debugger?
Bertrik
Re[2]: [lpc2000] Problem on starting uClinux on LPC2292...
2006-02-27 by Branko Karaklajic
Hello Bertrik,
BS> Branko Karaklajic wrote:
>> Hello everyone,
>> 4MB RAM!
>> ---CODE---
>> void kernel_jump()
>>      (*kernelstart)();
>> -END CODE-
>> of kernel...
BS> I think it's not needed to dereference kernelstart.
BS> Try invoking kernelstart simply as follows:
BS> kernelstart();
BS> Can you follow where it is going when doing this call with the
BS> JTAG debugger?
BS> Regards,
BS> Bertrik
Hm... I try that after I wrote letter to group... Very strange
behavior... if I do single step through that function and first few
assembly instruction of kernel... everything is fine..., but if I run
it on the full speed, I get garbage on console and reboot. Maybe
problem with oscillator configuration... I'm going to check that..
Any other suggestion!?
Best regards,
 Branko Karaklajic
Re[3]: [lpc2000][SOLVED] Problem on starting uClinux on LPC2292...
Hello Branko,
Problem is solved. If PLL is ON in bootloader, everything hang when
jump to kernel... Without PLL uClinux is runing with 7.21 BogoMIPS!
Thanx
BS>> Branko Karaklajic wrote:
>>> Hello everyone,
>>> 4MB RAM!
>>> ---CODE---
>>> void kernel_jump()
>>>      (*kernelstart)();
>>> -END CODE-
>>> of kernel...
BS>> I think it's not needed to dereference kernelstart.
BS>> Try invoking kernelstart simply as follows:
BS>> kernelstart();
BS>> Can you follow where it is going when doing this call with the
BS>> JTAG debugger?
BS>> Regards,
BS>> Bertrik
BK> Hm... I try that after I wrote letter to group... Very strange
BK> behavior... if I do single step through that function and first few
BK> assembly instruction of kernel... everything is fine..., but if I run
BK> it on the full speed, I get garbage on console and reboot. Maybe
BK> problem with oscillator configuration... I'm going to check that..
BK> Any other suggestion!?
Best regards,
 Branko Karaklajic
2006-02-27 by mhoneywill
Hi Roger,
Great program, thanks. One feature that would be great as well as
supporting non FBR LPC's is the ability to manually edit the required
baudrate field. i.e. if I wanted to run at 250000 baud (DMX) or 31250
baud (MIDI) or some other non standard rate.
Thanks again for the tool, just some ideas for improvements.
Cheers
Martin
> Hope this helps.
> Roger
2006-03-02 by Tong Le
Hi Mrs. Wright
  Could you email me that also?
  Thank you.
calculations.
Kathy Wright
UxDLL
nice to
for a
> factor.
> > Sutton - dodge55
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors     Pic microcontrollers
  YAHOO! GROUPS LINKS
 Yahoo! Mail
 Use Photomail to share photos without annoying attachments.
2006-03-02 by mhaines4102
I would like a copy as well if you don't mind.
--- In lpc2000@yahoogroups.com, Tong Le <gaquaycalifornia@...> wrote:
> Hi Mrs. Wright
>   Thank you.
> calculations.
> Kathy Wright
> UxDLL
> nice to
> for a
> > factor.
> > > Sutton - dodge55
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
>  Yahoo! Mail
2006-03-03 by philipp1024@web.de
may I have it too. Or could you  upload it to the LPC200 file section?
Thanks
Philipp
lpc2000@yahoogroups.com schrieb am 02.03.06 07:33:23:
> Hi Mrs. Wright
>   Thank you.
> calculations.
> Kathy Wright
> UxDLL
> nice to
> for a
> > factor.
> > > Sutton - dodge55
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
>  Yahoo! Mail
______________________________________________________________
Verschicken Sie romantische, coole und witzige Bilder per SMS!
Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
