Lpc2000
LPC2148 Register Definitions (Uart)
2006-02-24 by stephan2148
Can someone point me to the register definitions for the LPC2148?  I
am having UART troubles at full speed, although single stepping works.
I cannot find where the bit definitions are for all of the registers
that are shown in the IAR environment for example. The datasheet I
have Rev1 Sept7 2005, and the online Keil book don't seem to have all
of that either.  I can see the header file definitions, but without
comments.
Steve
Re: LPC2148 Register Definitions (Uart)
2006-02-24 by lpc2100_fan
Steve,
may be it is just a wording thing but when you refer to the data sheet
is it the User's Manual?
If not, the UM can be found here:
http://www.standardics.philips.com/support/documents/microcontrollers/pdf/user.manual.lpc2141.lpc2142.lpc2144.lpc2146.lpc2148.pdf
Cheers, Bob
--- In lpc2000@yahoogroups.com, "stephan2148" <stephan2148@...> wrote:
> Hi,
> comments.
> Thanks,
> Steve
--- In lpc2000@yahoogroups.com, "lpc2100_fan" <lpc2100_fan@...> wrote:
> Steve,
> Cheers, Bob
> --- In lpc2000@yahoogroups.com, "stephan2148" <stephan2148@> wrote:
Thankyou.  That is what I need.  I had only a 38 page datasheet of the
214x devices.  Now it should be a bit easier.
Steve
