Lpc2000
type cast in GCC
type cast in GCC
2006-02-28 by weartronics
Dear lpc2000,
In the Keil LPC2148 USB examples, EP0 buffer is declared as a byte array
BYTE  EP0Buf[USB_MAX_PACKET0];
but later it is type cast to the packed word array
*((__packed WORD *)EP0Buf) = 0;
I don't understand how the pointer EP0Buf would be changed by casting
it to the __packed word pointer. Is anyone able to explain the
function of the type cast to me so I can write a GCC equivalent (where
the type cast to a packed type is not supported)?
Nic
Re: [lpc2000] type cast in GCC
2006-02-28 by Dmitry Diky
Hi Nic,
I had the same problem...
It seems that Keil's __packed keyword in the front of a pointer effectively
means
memcpy(packed_p, source_p, sizeof(source));
In your case your can write
	EP0Buf[0] = 0;
	EP0Buf[1] = 0;
or just
*(short *)EP0Buf = 0;
if you add __atribute__((aligned(2))) to the EP0Buf declaration:
	char __atribute__((aligned(2))) EP0Buf[USB_MAX_PACKET0];
This will in result write to assembly:
	.comm EP0Buf, USB_MAX_PACKET0, 2
where last digit '2' is an optional align passed to linker.
Have fun,
Dmitry.
P.S. in my case I couldn't run Keil's example on my board with gcc anyway.
On Tuesday 28 February 2006 05:54, weartronics wrote:
> Dear lpc2000,
> Thanks,
> Nic
Re: type cast in GCC
2006-02-28 by bdmlpc
--- In lpc2000@yahoogroups.com, "weartronics" <nic@...> wrote:
> Dear lpc2000,
> Thanks,
> Nic
Hi Nic,
the __packed keyword or __attribute__((packed)) statement should
prevent compiler from optimizing memory storage of variables and
memory accesses. Appling these statements to a structure for example
means that the compiler should put all struct-members together.
Otherwise the compiler could insert "padding bytes" to align
u16-variables to 2-byte-boundaries and u32-variables to
4-byte-boundaries to prevent mis-aligned memory accesses (which need
more than one memory cycle) on some architectures. __packed forces the
compiler not to optimize.
In your particular case I'm not sure if __packed is really needed,
because due to the cast the compiler is still forced to work on a
(maybe) mis-aligned adress pointer.
  Sten
2006-02-28 by nic@weartronics.com
Hi Dmitry,
Thanks, this makes some sense now. I wish Keil had documented the __packed
better (I looked at the manual on their web site but it doesn't discuss a
__packed typecast and I would never have guessed that the typecast
actually rearranges the array memory!) I'll give this a go next. Thanks
also for your info bdmlpc.
Kind regards,
Nic
> Hi Nic,
> effectively
> means
> 	EP0Buf[0] = 0;
> 	EP0Buf[1] = 0;
> or just
> Have fun,
> Dmitry.
>> Dear lpc2000,
>> Thanks,
>> Nic
>> Yahoo! Groups Links
