Lpc2000
Flash Downloading with CrossStudio
2006-03-01 by timothymarknorton
Hi All,
I am new to ARM and currently working on a design that uses and
LPC2131.  I am using CrossStudio and having some problems.  When I
start debugging it gives me Verification errors after downloading.  I
am using a Seggar J-Link that came in an IAR kickstart kick.  The
verification errors begin at 0x1000.  Anything before that programs
just fine.  Any ideas?
Mark
Re: Flash Downloading with CrossStudio
2006-03-01 by arm7dude
Mark
It's quite possible that you need to update you JLink driver. The
current on is 3.12c. I've seen a lot of problems downloading with the
older drivers. Hope this helps.
Ed
--- In lpc2000@yahoogroups.com, "timothymarknorton"
<timothymarknorton@...> wrote:
> Hi All,
> Mark
Re: [lpc2000] Re: Flash Downloading with CrossStudio
2006-03-01 by Mark Norton
For a bit more info:
I have a demo board with a LPC2138 and the code will
download to it just fine.  On my product which has a
LPC2131 it won't.
--- arm7dude <arm7dude@...> wrote:
> Mark
> JLink driver. The
> Ed
> > Hi All,
> that uses and
> problems.  When I
> kickstart kick.  The
> > Mark
Do You Yahoo!?
http://mail.yahoo.com
2006-03-02 by Mark Norton
It turns out that my problem was with the CrossWorks
loader.  The code didn't have support for the LPC2131
and the default was another "geometry".  I added
support and all is good.
On a side note, I tried upgrading the firmware and
driver for the j-link.  This caused me all sorts of
grief with CrossWorks.  I would get USB communication
failures, timeouts, ect...  I could unplug/disconnect
the j-link and say a little chant and it would work
for a bit and then quite.  As it turns out, the new
driver/firmware comes with a new dll.  Once I replaced
the dll in the CrossWorks bin directory, all is good
again.
> LPC2131 it won't.
> > Mark
> > JLink driver. The
> > Ed
> "timothymarknorton"
> > > Hi All,
> design
> > that uses and
> > problems.  When I
> > kickstart kick.  The
> > > Mark
> Do You Yahoo!?
> protection around
Do You Yahoo!?
