Lpc2000
EEPROM polling in I2C interrupt routine
2006-03-03 by Jacek Domanski
Hello All,
I have a problem with EEPROM polling in my  I2C interrupt routine (for
LPC2114).
After write sequence, there should be done polling and EEPROM should not ack
when I'm trying to access it - for time of internal write sequence (as
Microchip write in the EEPROM datasheet).
I don't know why but unfortunatelly this is not a true - EEPROM always answers
ACK (probably - there is no 0x20 or 0x30 state from I2STAT).
When I completely switch off EEPROM - this states shows, so it looks that LPC
works fine.
When I'm trying to read memory immediately after write - there are some
errors, and received bytes differs from that I just wrote.
When I put a delay routine between write and read - it works.
It looks that internal address counter in the memory is set wrong (too fast
access after write?)
So - the question is - what can I do with it? :-)
I'm new in the field of ARM processors, so maybe I make some mistakes?
Best Regards,
Jado.
