Lpc2000
LPC2138 GPIO Pull Downs ?
2006-03-06 by nknight62
We have an application where we use the GPIO I/O pins on Port 1 of
LPC2138 to an LCV244 buffer/driver.  We found that randomly, some pins
on the buffer driver were high or low at power-up with no program
loaded to control the pins.  We added 32k pull downs between the 2138
and the buffer/driver inputs to pull the lines low because the GPIO
lines are floating inputs before program changes them into outputs.
However, we are still randomly seeing some outputs on buffer/driver
high and some low on power up.  We measured between 0.4 and 1.2 volts
on those lines. Why are 32k pull downs not working for us ?
Nick
Re: [lpc2000] LPC2138 GPIO Pull Downs ?
2006-03-06 by Karl Olsen
---- Original Message ----
To: <lpc2000@yahoogroups.com>
Sent: Monday, March 06, 2006 6:44 AM
Subject: [lpc2000] LPC2138 GPIO Pull Downs ?
Remember that all P1.x pins have internal pull-ups of 60-300 kohm.
Karl Olsen
Re: LPC2138 GPIO Pull Downs ?
2006-03-06 by pitstock_kiwi
It seems there is and error in the data sheet or I have measured the
chip wrong. I have tested on a 2148 and a 2142 and found the
following.
The Data sheet states "P1.29/TCK 56 *[6] I/O P1.29 - General purpose
digital input/output pin"
"*[6] - 5 V tolerant pad with built-in pull-up resistor providing
digital I/O functions with TTL levels and hysteresis
and 10 ns slew rate control. The pull-up resistor's value typically
ranges from 60 k to 300 k"
Basically this claims that the P1.29 has a minimum pull up of 300k.
My measurements show a pullup of around 5 megs which is probably just
leakage. Am I the only one that has found this ? This seems to be the
case on all the JTAG pins.
Keith
2006-03-07 by Jayasooriah
Hi Nick, something similar happens in LPC2292.
Although user manual says "All Port 1 pins are 5V tolerant with built-in
pull-up resistor that sets input level to high when corresponding pin is
used as input", I found this not to be the case because of "external boot"
feature provided by the boot loader that is mentioned elsewhere as BOOT1:0
signals.
What this "feature" does is configures external memory to 8/16/32 bit mode
depending on P2.26 and P2.27 at reset.  When this happens, some pins of P1
assume external memory interface functions and thus become outputs.  The
code implementing this feature in LPC2292 boot loader V 1.64 appears strange.
Try making sure that P2.26-27 are not connected (and depend on internal
pull-up) to see if you still get this behaviour.  If you have things
connected to these pins, the other option active pull-up during reset.
Hope this helps.
Jaya
>Message: 6
>    Date: Mon, 06 Mar 2006 05:44:25 -0000
>    From: "nknight62" <justlooking@...>
>Subject: LPC2138 GPIO Pull Downs ?
>Regards,
>Nick
Send instant messages to your online friends http://au.messenger.yahoo.com
RE: [lpc2000] LPC2138 GPIO Pull Downs ?
2006-03-09 by nknight
*       We have an application where we use the GPIO I/O pins on Port 1 of
Karl Olsen
All,
I appreciate all who replied. Because we needed to ensure that all of our
outputs were held low through reset, we utilized the gate enable pins on the
LVC244 buffers to hold buffer output low through reset, then programmed an
output pin to drive gate enable pins low once our program is up and running.
Nick
SPONSORED LINKS
Microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2
=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.s
ig=mfaAujKZXA2Z_vxre9sGnQ>
Microprocessor
<http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=M
icroprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig
=9jjd2D3GOLIESVQssLmLsA>
Intel
<http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrolle
rs&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=
95&.sig=OMnZuqMZX95mgutt4B-tDw>  microprocessors
Pic
<http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontroller
s&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=9
5&.sig=Malspbd0T4Rq3M4Q0nHrfw>  microcontrollers
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> "
on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
  _____
