Lpc2000
`/etc/startup.mk' not found
2006-03-07 by kbshah_2000
Hi guys.
I am new with GNU arm. (I have used IAR).
After downloading I have installed winarm and tried to compile example
code but I get following message...
Any body having similar issue (I have downloaded winarm from
jan17,2006 ...
Any solution suggestion. I have defined my winarm/bin path
> "make.exe" all
make.exe:  Error -- configuration file `/etc/startup.mk' not found
> Process Exit Code: 255
> Time Taken: 00:00
Thanks
kb shah
Re: [lpc2000] `/etc/startup.mk' not found
2006-03-07 by Thiago Takehara
maybe your makefile tries to find this dependency. Please, send your makefile so
I can see what it needs to build your target.
Thiago Takehara
Computer Engineer
Engworks Industrial LTDA - R&D Division
  To: lpc2000@yahoogroups.com
  Sent: Tuesday, March 07, 2006 4:25 PM
  Subject: [lpc2000] `/etc/startup.mk' not found
  Hi guys.
  jan17,2006 ...
  > "make.exe" all
  > Time Taken: 00:00
  Thanks
  kb shah
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
        Pic microcontrollers
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2006-03-07 by K B Shah-lascaux
Here is the make  file :(I have modifed paths  for my winarm]
(This file came with the example that are installed with installation.)
I am also sending example code .
Thanks in advance...
(There are mode examples i have tried other 2-3 with similar result)
I have attached project as well as reproduced the make file here for reference.
# Hey Emacs, this is a -*- makefile -*-
# WinARM template makefile
# by Martin Thomas, Kaiserslautern, Germany
# <eversmith@...>
# based on the WinAVR makefile written by Eric B. Weddington, Jörg Wunsch, et al.
# Released to the Public Domain
# Please read the make user manual!
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make program = Download the hex file to the device, using lpc21isp
# (TODO: make filename.s = Just compile filename.c into the assembler code only)
# To rebuild project do "make clean" then "make all".
# Changelog:
# - 17. Feb. 2005  - added thumb-interwork support (mth)
# - 28. Apr. 2005  - added C++ support (mth)
# - 29. Arp. 2005  - changed handling for lst-Filename (mth)
# MCU name and submodel
MCU = arm7tdmi
SUBMDL = LPC2106
#THUMB    = -mthumb
#THUMB_IW = -mthumb-interwork
## Create ROM-Image (final)
RUN_MODE=ROM_RUN
## Create RAM-Image (debugging)
#RUN_MODE=RAM_RUN
# Output format. (can be srec, ihex, binary)
FORMAT = ihex
# Target file name (without extension).
TARGET = ledswitch
# List C source files here. (C dependencies are automatically generated.)
# use file-extension c for "c-only"-files
SRC = $(TARGET).c
#SRC =
# List C source files here which must be compiled in ARM-Mode.
SRCARM =
# List C++ source files here.
# use file-extension cpp for C++-files
CPPSRC =
# List C++ source files here which must be compiled in ARM-Mode.
# CPPSRCARM = $(TARGET).cpp
CPPSRCARM =
# List Assembler source files here.
# Make them always end in a capital .S.  Files ending in a lowercase .s
# will not be considered source files but generated files (assembler
# output from the compiler), and will be deleted upon "make clean"!
# Even though the DOS/Win* filesystem matches both .s and .S the same,
# it will preserve the spelling of the filenames, and gcc itself does
# care about how the name is spelled on its command-line.
ASRC =
# List Assembler source files here which must be assembled in ARM-Mode..
ASRCARM = build/crt0.S
# Optimization level, can be [0, 1, 2, 3, s].
# 0 = turn off optimization. s = optimize for size.
# (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
OPT = s
# Debugging format.
# Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
# AVR (extended) COFF requires stabs, plus an avr-objcopy run.
#DEBUG = stabs
DEBUG = dwarf-2
# List any extra directories to look for include files here.
#     Each directory must be seperated by a space.
#EXTRAINCDIRS = ./include
EXTRAINCDIRS =
# Compiler flag to set the C Standard level.
# c89   - "ANSI" C
# gnu89 - c89 plus GCC extensions
# c99   - ISO C99 standard (not yet fully implemented)
# gnu99 - c99 plus GCC extensions
CSTANDARD = -std=gnu99
# Place -D or -U options for C here
CDEFS =  -D$(RUN_MODE)
# Place -I options here
CINCS =
# Place -D or -U options for ASM here
ADEFS =  -D$(RUN_MODE)
# Compiler flags.
#  -g*:          generate debugging information
#  -O*:          optimization level
#  -f...:        tuning, see GCC manual and avr-libc documentation
#  -Wall...:     warning level
#  -Wa,...:      tell GCC to pass this to the assembler.
#    -adhlns...: create assembler listing
# Flags for C and C++ (arm-elf-gcc/arm-elf-g++)
CFLAGS = -g$(DEBUG)
CFLAGS += $(CDEFS) $(CINCS)
CFLAGS += -O$(OPT)
CFLAGS += -Wall -Wcast-align -Wcast-qual -Wimplicit
CFLAGS += -Wpointer-arith -Wswitch
CFLAGS += -Wredundant-decls -Wreturn-type -Wshadow -Wunused
#CFLAGS += -Wa,-adhlns=$(<:.c=.lst)
CFLAGS += -Wa,-adhlns=$(subst $(suffix $<),.lst,$<)
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
# flags only for C
CONLYFLAGS  = -Wstrict-prototypes -Wmissing-declarations
CONLYFLAGS += -Wmissing-prototypes -Wnested-externs
CONLYFLAGS += $(CSTANDARD)
# flags only for C++ (arm-elf-g++)
CPPFLAGS =
# Assembler flags.
#  -ahlms:    create listing
#  -gstabs:   have the assembler create line number information; note that
#             for use in COFF files, additional information about filenames
#             and function names needs to be present in the assembler source
#             files -- see avr-libc docs [FIXME: not yet described there]
##ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs
ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:.S=.lst),-g$(DEBUG)
#Additional libraries.
#Support for newlibc-lpc (file: libnewlibc-lpc.a)
#NEWLIBLPC = -lnewlib-lpc
NEWLIBCLPC =
MATH_LIB = -lm
# Linker flags.
#  -Wl,...:     tell GCC to pass this to linker.
#    -Map:      create map file
#    --cref:    add cross reference to  map file
LDFLAGS = -nostartfiles -Wl,-Map=$(TARGET).map,--cref
LDFLAGS += -lc
LDFLAGS += $(NEWLIBLPC) $(MATH_LIB)
LDFLAGS += -lc -lgcc
# Set Linker-Script Depending On Selected Memory
ifeq ($(RUN_MODE),RAM_RUN)
LDFLAGS +=-Tbuild/$(SUBMDL)-RAM.ld
else
LDFLAGS +=-Tbuild/$(SUBMDL)-ROM.ld
endif
# Flash-Programming support using lpc21isp by Martin Maurer
# Settings and variables:
LPC21ISP = lpc21isp
#LPC21ISP = lpc21isp_beta
LPC21ISP_PORT = com1
LPC21ISP_BAUD = 115200
LPC21ISP_XTAL = 14746
LPC21ISP_FLASHFILE = $(TARGET).hex
# verbose output:
## LPC21ISP_DEBUG = -debug
# enter bootloader via RS232 DTR/RTS (only if hardware supports this
# feature - see Philips AppNote):
LPC21ISP_CONTROL = -control
#********* Following section was changed by me as per my install configuration*****
# Define directories, if needed.
 DIRARM = d:\WinARM\
 DIRARMBIN = $(DIRARM)\bin\
 DIRARMUTILS = $(DIRARM)\utils\bin\
#********* above section was changed by me as per my install configuration*****
# Define programs and commands.
SHELL = sh
CC = arm-elf-gcc
CPP = arm-elf-g++
OBJCOPY = arm-elf-objcopy
OBJDUMP = arm-elf-objdump
SIZE = arm-elf-size
NM = arm-elf-nm
REMOVE = rm -f
COPY = cp
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = -------- begin --------
MSG_END = --------  end  --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_FLASH = Creating load file for Flash:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling C:
MSG_COMPILING_ARM = "Compiling C (ARM-only):"
MSG_COMPILINGCPP = Compiling C++:
MSG_COMPILINGCPP_ARM = "Compiling C++ (ARM-only):"
MSG_ASSEMBLING = Assembling:
MSG_ASSEMBLING_ARM = "Assembling (ARM-only):"
MSG_CLEANING = Cleaning project:
MSG_LPC21_RESETREMINDER = You may have to bring the target in bootloader-mode now.
# Define all object files.
COBJ      = $(SRC:.c=.o)
AOBJ      = $(ASRC:.S=.o)
COBJARM   = $(SRCARM:.c=.o)
AOBJARM   = $(ASRCARM:.S=.o)
CPPOBJ    = $(CPPSRC:.cpp=.o)
CPPOBJARM = $(CPPSRCARM:.cpp=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(ASRCARM:.S=.lst) $(SRC:.c=.lst) $(SRCARM:.c=.lst)
LST += $(CPPSRC:.cpp=.lst) $(CPPSRCARM:.cpp=.lst)
# Compiler flags to generate dependency files.
### GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d
GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mcpu=$(MCU) $(THUMB_IW) -I. $(CFLAGS) $(GENDEPFLAGS)
ALL_ASFLAGS = -mcpu=$(MCU) $(THUMB_IW) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: begin gccversion sizebefore build sizeafter finished end
build: elf hex lss sym
elf: $(TARGET).elf
hex: $(TARGET).hex
lss: $(TARGET).lss
sym: $(TARGET).sym
# Eye candy.
begin:
 @echo
 @echo $(MSG_BEGIN)
finished:
 @echo $(MSG_ERRORS_NONE)
end:
 @echo $(MSG_END)
 @echo
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) -A $(TARGET).elf
sizebefore:
 @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); echo; fi
sizeafter:
 @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); echo; fi
# Display compiler version information.
gccversion :
 @$(CC) --version
# Program the device.
program: $(TARGET).hex
 @echo
 @echo $(MSG_LPC21_RESETREMINDER)
 $(LPC21ISP) $(LPC21ISP_CONTROL) $(LPC21ISP_DEBUG) $(LPC21ISP_FLASHFILE) $(LPC21ISP_PORT) $(LPC21ISP_BAUD) $(LPC21ISP_XTAL)
# Create final output files (.hex, .eep) from ELF output file.
# TODO: handling the .eeprom-section should be redundant
%.hex: %.elf
 @echo
 @echo $(MSG_FLASH) $@
 $(OBJCOPY) -O $(FORMAT) $< $@
# Create extended listing file from ELF output file.
# testing: option -C
%.lss: %.elf
 @echo
 @echo $(MSG_EXTENDED_LISTING) $@
 $(OBJDUMP) -h -S -C $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
 @echo
 @echo $(MSG_SYMBOL_TABLE) $@
 $(NM) -n $< > $@
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM)
%.elf:  $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM)
 @echo
 @echo $(MSG_LINKING) $@
 $(CC) $(THUMB) $(ALL_CFLAGS) $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM) --output $@ $(LDFLAGS)
# $(CPP) $(THUMB) $(ALL_CFLAGS) $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM) --output $@ $(LDFLAGS)
# Compile: create object files from C source files. ARM/Thumb
$(COBJ) : %.o : %.c
 @echo
 @echo $(MSG_COMPILING) $<
 $(CC) -c $(THUMB) $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@
# Compile: create object files from C source files. ARM-only
$(COBJARM) : %.o : %.c
 @echo
 @echo $(MSG_COMPILING_ARM) $<
 $(CC) -c $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@
# Compile: create object files from C++ source files. ARM/Thumb
$(CPPOBJ) : %.o : %.cpp
 @echo
 @echo $(MSG_COMPILINGCPP) $<
 $(CPP) -c $(THUMB) $(ALL_CFLAGS) $(CPPFLAGS) $< -o $@
# Compile: create object files from C++ source files. ARM-only
$(CPPOBJARM) : %.o : %.cpp
 @echo
 @echo $(MSG_COMPILINGCPP_ARM) $<
 $(CPP) -c $(ALL_CFLAGS) $(CPPFLAGS) $< -o $@
# Compile: create assembler files from C source files. ARM/Thumb
## does not work - TODO - hints welcome
##$(COBJ) : %.s : %.c
## $(CC) $(THUMB) -S $(ALL_CFLAGS) $< -o $@
# Assemble: create object files from assembler source files. ARM/Thumb
$(AOBJ) : %.o : %.S
 @echo
 @echo $(MSG_ASSEMBLING) $<
 $(CC) -c $(THUMB) $(ALL_ASFLAGS) $< -o $@
# Assemble: create object files from assembler source files. ARM-only
$(AOBJARM) : %.o : %.S
 @echo
 @echo $(MSG_ASSEMBLING_ARM) $<
 $(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list finished end
clean_list :
 @echo
 @echo $(MSG_CLEANING)
 $(REMOVE) $(TARGET).hex
 $(REMOVE) $(TARGET).obj
 $(REMOVE) $(TARGET).elf
 $(REMOVE) $(TARGET).map
 $(REMOVE) $(TARGET).a90
 $(REMOVE) $(TARGET).sym
 $(REMOVE) $(TARGET).lnk
 $(REMOVE) $(TARGET).lss
 $(REMOVE) $(COBJ)
 $(REMOVE) $(CPPOBJ)
 $(REMOVE) $(AOBJ)
 $(REMOVE) $(COBJARM)
 $(REMOVE) $(CPPOBJARM)
 $(REMOVE) $(AOBJARM)
 $(REMOVE) $(LST)
 $(REMOVE) $(SRC:.c=.s)
 $(REMOVE) $(SRC:.c=.d)
 $(REMOVE) $(SRCARM:.c=.s)
 $(REMOVE) $(SRCARM:.c=.d)
 $(REMOVE) $(CPPSRC:.cpp=.s)
 $(REMOVE) $(CPPSRC:.cpp=.d)
 $(REMOVE) $(CPPSRCARM:.cpp=.s)
 $(REMOVE) $(CPPSRCARM:.cpp=.d)
 $(REMOVE) .dep/*
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion \
build elf hex lss sym clean clean_list program
K B Shah
  Sent: Tuesday, March 07, 2006 3:39 PM
  Subject: Re: [lpc2000] `/etc/startup.mk' not found
  Thiago Takehara
  Computer Engineer
    Hi guys.
    jan17,2006 ...
    > "make.exe" all
    > Time Taken: 00:00
    Thanks
    kb shah
    YAHOO! GROUPS LINKS
  YAHOO! GROUPS LINKS
  Checked by AVG Free Edition.
  Version: 7.1.375 / Virus Database: 268.2.0/275 - Release Date: 06/03/2006
I believe this error you got has nothing with your makefile, even with your source codes. I´ve googled a little about this error message and found answers like "copy the startup.mk file from /samples to /etc". Are you running your make.exe from the same path where your makefile is? Have you ever tried to force your make.exe to use your makefile, i.e., 'make.exe -f makefile'? Maybe it works for you.
I have not found anything weird in you makefile, neither found references for 'startup.mk', so I believe it has nothing with your source files.
I couldn´t get the files you said you sent, maybe Yahoo blocked out the attaches.
Good luck, if I find any clue I´ll tell you.
Thiago Takehara
Computer Engineer
  Sent: Tuesday, March 07, 2006 6:00 PM
  # <eversmith@...>
  # On command line:
  # Changelog:
  MCU = arm7tdmi
  SUBMDL = LPC2106
  #THUMB    = -mthumb
  RUN_MODE=ROM_RUN
  #RUN_MODE=RAM_RUN
  FORMAT = ihex
  TARGET = ledswitch
  SRC = $(TARGET).c
  #SRC =
  SRCARM =
  CPPSRC =
  CPPSRCARM =
  ASRC =
  OPT = s
  # Debugging format.
  #DEBUG = stabs
  DEBUG = dwarf-2
  EXTRAINCDIRS =
  # c89   - "ANSI" C
  CINCS =
  # Compiler flags.
  CFLAGS = -g$(DEBUG)
  CFLAGS += -O$(OPT)
  # flags only for C
  CPPFLAGS =
  # Assembler flags.
  NEWLIBCLPC =
  MATH_LIB = -lm
  # Linker flags.
  LDFLAGS += -lc
  else
  endif
  LPC21ISP = lpc21isp
  # verbose output:
  DIRARM = d:\WinARM\
  SHELL = sh
  CC = arm-elf-gcc
  CPP = arm-elf-g++
  SIZE = arm-elf-size
  NM = arm-elf-nm
  REMOVE = rm -f
  COPY = cp
  # Define Messages
  # English
  COBJ      = $(SRC:.c=.o)
  # Default target.
  elf: $(TARGET).elf
  hex: $(TARGET).hex
  lss: $(TARGET).lss
  sym: $(TARGET).sym
  # Eye candy.
  begin:
  @echo
  @echo $(MSG_BEGIN)
  finished:
  end:
  @echo $(MSG_END)
  @echo
  sizebefore:
  sizeafter:
  gccversion :
  @$(CC) --version
  @echo
  %.hex: %.elf
  @echo
  %.lss: %.elf
  @echo
  %.sym: %.elf
  @echo
  $(NM) -n $< > $@
  @echo
  $(COBJ) : %.o : %.c
  @echo
  @echo
  @echo
  @echo
  $(AOBJ) : %.o : %.S
  @echo
  @echo
  clean_list :
  @echo
  $(REMOVE) $(COBJ)
  $(REMOVE) $(CPPOBJ)
  $(REMOVE) $(AOBJ)
  $(REMOVE) $(LST)
  $(REMOVE) .dep/*
  K B Shah
    Thiago Takehara
    Computer Engineer
      Hi guys.
      jan17,2006 ...
      > "make.exe" all
      > Time Taken: 00:00
      Thanks
      kb shah
      YAHOO! GROUPS LINKS
    YAHOO! GROUPS LINKS
       lpc2000-unsubscribe@...m
  YAHOO! GROUPS LINKS
