Lpc2000
SPI Code hangs
SPI Code hangs
2006-03-08 by brightside_design
I have a problem with a simple SPI example program.
Part: LPC2129
PCK: 14.7 MHz
Mode: Master, CPOL=0, CPHA=0, LSIF=0.
I initialise the SPI like this:-
void SPI_Init(void)
	S0SPCCR = 0x26;	// Divides PCK to give about 400kHz
	S0SPCR = 0x20;	// Select Master mode
And then use the SPI like this:-
void SPI_Transfer( char *buf, int count)
	int r = 0, i = 0;
	for( ; i < count; i++ )
		S0SPDR = buf[i];	// Write data
		do{ r = S0SPSR; }while(!(r & 0x80));// Wait for SPIF
		// Read status - to be done
		buf[i] = S0SPDR;	// Read data
Sometimes I power up the device and this function runs correctly
with problem whatsoever. Other times the function just hangs. If I
attach a JTAG debugger (Keil ULINK) I find that the function is
hanging at the line "do{ r = S0SPSR; }while(!(r & 0x80));" on the
first itteration.
There is no hardware attached to the SPI port. I figured that the
device should put data out onto an unconnected pin without any
problem and that I should be able to get the software working before
thinking about ading hardware.
Has anyone got any ideas what might be going wrong?
Re: [lpc2000] SPI Code hangs
2006-03-09 by Tom Walsh
>Part: LPC2129
>PCK: 14.7 MHz
>void SPI_Init(void)
>	int r = 0, i = 0;
Try writing it this way:
volatile int r = 0;
volatile int i = 0;
If you look deeper at the underlying assembly language via the JTAG, I'm
fairly confident you will find that it reads "r" once, then loops on the
resultant value.  Essentially, the volatile keyword tells the compiler
to assume nothing about the variables' value it holds, to actually check
it rather than to optimize the reference.
YMMV, but your function would probably work if you turned off all
optimizations (-O0).
TomW
>first itteration.
>Thanks,
>Paul
>Yahoo! Groups Links
Re: SPI Code hangs
2006-03-09 by brightside_design
> >Part: LPC2129
> >PCK: 14.7 MHz
> >void SPI_Init(void)
> >	int r = 0, i = 0;
> volatile int r = 0;
> volatile int i = 0;
JTAG, I'm
on the
compiler
check
> TomW
I
> >first itteration.
before
> >Thanks,
> >Paul
Thanks Tom, I will try that when I have a moment but I don't think
thats the answer. I've just read through the disassemby for that
function and it is reading the register each time through. Also the
problem is intermittant, sometimes it works fine, other times it
hangs.
Re: [lpc2000] Re: SPI Code hangs
>>>Part: LPC2129
>>>PCK: 14.7 MHz
>>>void SPI_Init(void)
>>>	int r = 0, i = 0;
>>volatile int r = 0;
>>volatile int i = 0;
>JTAG, I'm
>on the
>compiler
>check
>>TomW
>I
>>>first itteration.
>before
>>>Thanks,
>>>Paul
>hangs.
I have a state machine which is servicing three MAX3100 UARTS on the SPI
circuit.  The state machine steps are governed by the SPI interrupt.
Each time an SPI interrupt fires, the state machine advances one step.
  The machine runs until all UARTS are "quiet", meaning nothing to
transmit and nothing in the recievers.  Then the machine shuts down.
The state machine is driven by the SPI interrupt, however, the initial
"kick-off" of putting the machine into motion is handled by two external
conditions:
1) EXTINT0 is triggered by a wired-OR of the IRQ output of the MAX3100's
(interrupt asserted only on RX data available).
2) Data has been entered into one of the transmit queues.  In which
case, the EXTINT0 ISR is soft triggered via  VICSoftInt bit.
That is the structure of my ISR and it's relation to the other software
in the system.  What I'd found was that this state machine / VICSoftInt
mechanism would run fine for a while, then randomly the SPI ISR would
deadlock looking for the SPI completion bit.  The only way I've found
out of that deadlock was to put a timeout in the code which looks at the
completion bit:
================= begin spiISR() ==============
void spi0ISR (void)
{// state machine to service the uarts.
volatile ushort byt;
   for (byt=0x80; byt; byt--) if (SPSR & 0x80) break;
   switch (spiState) {
         // handler for serial2
      case Srx2step0:   // begin the walk down all three uarts.
            // assume shutdown in final state...
            // but any activty will force a new cycle to run.
         AllIsQuietOnSpi = True;
         dataWord = getS2DataTosend();
            // send first byte on its way.
         IOCLR = SEL2_BIT;
         spiState = Srx2step1;
         SPDR = (dataWord >> 8);
         break;
================== snip ================
This works for me.  I don't like it, but it works.  I'd spent several
days trying to work out why the SPI would deadlock and could not find
any explanation.  What I did find out is that the SPI interrupt would
fire well before the SPIF completion bit was set!!!
This was proven by examining the value of the "byt" variable in my above
routine.  It always showed that a significant number of loops occurred
before the SPIF bit was seen.  There were random intervals in which the
for() loop would expire to full count (zero).  After some testing, I
arrived at the value of 0x80 as the loop value which was twice the worst
case delay count awaiting the SPIF bit (when it did not goto zero).
So, I would arrive at the spiISR service and have to wait for the
completion bit.  Sometimes there would be an interrupt, but never a
completion bit.  I also found that I had to wait until that bit appeared
otherwise if I assumed that because I was in the ISR due to a completed
cycle and simply load the next byte into the SPI data register, the SPI
would sometimes die with a WCOL write collision!
According to the docs, there is absolutely no information nor timing
diagrams detailing the relationship of: the SPIF bit, shift clock, and
interrupts.  Again, the Philips docs are sadly lacking in detail on
critical issues (see discussion in this group messages regarding the ADC
leakage).
This is with the LPC2106 processor.  Interestingly, the SSI of the
LPC2138 does not suffer from this problem...  So, there appears to be an
as yet documented failure / weakness in the LCP2106 SPI controller.
Given that I was three months into this new board, had my first
prototype and was commited to using the Philips part, I had to "deal
with it".  Not like I've been here before.  :-/
The random deadlock is explained as a race condition between when the
interrupt fired and when I actually reloaded the SPI TX register.  Most
times I would be outside of the time between the SPI interrupt and SPIF
flagging, but sometimes I would hit it and lockup the SPI controller.
I cannot explain why the SPIF bit is missed however. That appears to be
a race condition in the silicon where a co-incidence of reading from the
SPI status register vs. the AHB writing into the status register... ???
TomW
>>>Part: LPC2129
>>>PCK: 14.7 MHz
>>>void SPI_Init(void)
>>>	int r = 0, i = 0;
>>volatile int r = 0;
>>volatile int i = 0;
>JTAG, I'm
>on the
>compiler
>check
>>TomW
>I
>>>first itteration.
>before
>>>Thanks,
>>>Paul
>hangs.
Oh, just some further information.  The LPC2106 is running  the SPI
under interrupts while the LCP2138 is not.  Here is a sample of the SSI
bit polling on the LPC2138:
========== begin spiPutByte() ============
static void spiPutByte(uchar inBuf)
{// spit a byte of data at the MMC.
   SSPDR = (REG16) inBuf; while (SSPSR & SSP_BSY);
      // dummy read clears SPI BSY flag on LPC2xxx processors.
   dummyReader = (uchar) SSPDR;
I am not yet using the SPI on the LPC2138, so that doesn't prove
anything other than the SSI is more durable?
TomW
Re: SPI Code hangs
2006-03-09 by c.barbaro
Hi.
I had no time to enter in depth regarding your problem but when
I read your phrase:
"I cannot explain why the SPIF bit is missed however. That appears to
be a race condition in the silicon where a co-incidence of reading
from the SPI status register vs. the AHB writing into the status
register... ???"
I remembered the errata document for the LPC2138 processor where
similar problems are documented for both the timer and the uart.
If you write a register via software at the same time that hardware
want to write the same register, the hardware write is not performed.
For timer this occurs when you are clearing a timer match interrupt
(ex. interrupt on match0) and another match occurs at the same time
(ex. match1): the match interrupt is never generated.
For uart this occurs if you read the IIR register, clearing the THRE
bit and at the same time the transmitter register become empty so that
hardware want to set the THRE bit: the bit is never set, the interrupt
is never generated.
The consequence is: if timers and uarts have these problems, why not
the SPI?
Have you checked the ERRATA for the LPC2106?
Anyway, I agree that "there is absolutely no information nor timing
ADC leakage)."
I know of my colleague working with SPI on LPC2138 and finding a lot
of problems.
I think that Philips failed create a microcontroller with "robust"
peripherals to be used in industrial environment.
Unfortunately (or fortunately??) it is very cheap, and this attract
the marketing peoples (the programmers will patch the code in one mode
or another...)
Good luck,
Carlo
> TomW
c.barbaro wrote:
>Hi.
>I read your phrase:
>register... ???"
>is never generated.
>the SPI?
Yes, and I do think that you are correct.   It may be an inherent design
failure of the AHB.  The discussion in apnote AN10414 strongly suggests
to me that there are such flaws in the hardware mechanisms between the
ARM core and the peripheral bus.
>ADC leakage)."
>of problems.
>or another...)
Well, I don't think that we can really fault Philips for some of this.
IMO, ARM Inc. itself shares some of this blame.  I see that ARM Inc. is
the one pushing / offering the AHB peripheral bus.  I suspect that
Philips collected the LPC2000 series together, Ala Carte, from a menu of
IP available from ARM.  So, design flaws in the AHB are being
promulgated into customers' silicon.
The documentation issue is a real black-eye though.  I've been designing
systems for a long time now and the documentation for the LPC2000 series
is atrocious!  The documentation is okay for writing software, but the
hardware documentation is simply terrible!
For example: refer to Philips document UM10120 "LPC213x User Manual".
Look at Section 12.4.5 "SPI Interrupt register (S0SPINT -
0xE002 001C)".  The only mention of the relationship of the SPI data
register shifting to an empty state and the occurance of the interrupt is:
"SPI interrupt flag. Set by the SPI interface to generate an interrupt.
Cleared by writing a 1 to this bit.
Note: this bit will be set once when SPIE = 1 and at least one of SPIF
and WCOL bits is 1. However, only when the SPI Interrupt bit is set and
SPI0 Interrupt is enabled in the VIC, SPI based interrupt can be
processed by interrupt handling software."
That is it!  No timing diagram or flow chart to explain the process.
Just a vague statement that the interrupt bit is used to set an
interrupt condition.  This is a childish explanation, thoroughly lacking
in any detail.  Any embedded engineer knows what an interrupt does, we
need to know WHEN you set the interrupt, what is the relationship of the
SPIF + SPINT?
1) Which comes first, the SPIF or SPINT?
2) At what clock & edge does the SPIF become asserted?
3) At what clock & edge does SPINT get asserted?
Those are questions that hardware + software engineers need to have
answered.   Not some silly pablum about what an interrupt is.  The
documentation is okay as far as identifying where the registers are and
what bits are used for...  The documentation is littered with these
omissions.
Another example, what is the characteristic input capacitance of the
clock circuits?  I have an 18pf crystal, how many picofarads will the
processor pins represent when calculating the additional load
capacitance for proper crystal operation?  If the range is, say, from
3pf..13pf then document that so that we are aware that the loading
capacitance may have to be altered in production due to silicon
fabrication differences.
Another example, what is the characteristic input resistance of the ADC
circuit?  Is that resistance a fixed value or does it change
significantly during conversion (conversion loading)?
Now, my question is, if this is not the definitive document we should be
looking at for this information: WHERE IS THE "REAL" DOCUMENTATION???
I just get very annoyed at having to spend days trying to 'get it right'
due to the lack of adequate documentation.  I am not a hobbyist, I do
this for a living.
TomW
Re: SPI Code hangs
2006-03-09 by Danish Ali
A quick sanity check:
You say you have no hardware attached.
You know you need a pull-up resistor on the SSEL pin,
which MUST be routed to the SPI block in PINSEL0.
The user manual tells you that you can't use the SSEL pin for GPIO
on devices earlier than the 2148 - even if you only ever use SSP as a master!
Without this, if the pin (or when wired as GPIO, the internal floating net)
goes low, the SPI will automatically be a slave.
imho this should be in an official "gotcha" document even if it is not an errata item.
Hope this helps,
Danish
--- In lpc2000@yahoogroups.com, "brightside_design" <brightside_design@...> wrote:
> Part: LPC2129
> PCK: 14.7 MHz
> first itteration.
> Thanks,
> Paul
2006-03-09 by Robert Adsett
Quoting Danish Ali <danish@...>:
> not an errata item.
See http://www.open-research.org.uk/ARMuC/LPC2100Tips.html
Robert
Re: SPI Code hangs
2006-03-10 by brightside_design
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@...>
as a master!
floating net)
is
> > not an errata item.
> Robert
I just added a pull-up to SSEL and it appears to be working! Thanks
for the help Danish and thank you Robert for the link; I'm sure I
would have been falling into one of the other "gotchas" in the next
few days!
Re: SPI Code hangs
2006-03-10 by brendanmurphy37
> completion bit:
Tom,
I presume you've seen and taken account of the LPC2106 erratum,
specifically the item "unintentional clearing of SPI interrupt flag" in
your investigations?
I'm not saying this is the cause of the behaviour you're seeing, but if
you haven't looked into this, it might be worth doing so.
Brendan
2006-03-10 by Tom Walsh
>the
>>completion bit:
>Tom,
Thank you, I am aware of that document.  It doesn't pertain to the
problem we are seeing.  The problem we are seeing is that at random
intervals the SPIF flag does not get set.  For myself, I have an ISR
which is triggered by the SPINT request, at the top of the ISR I loop
looking for the SPIF flag to be set.  Randomly, this flag fails to be
asserted by the hardware.  This causes my ISR to deadlock.
I had found that even if you got an SPINT which brough you into the ISR,
you cannot write into the SPDR until SPIF is set.  Otherwise a WCOL
would be raised.  So, you have to wait in the ISR until SPIF is raised,
usually this takes 10..20 interations of a simple for() loop polling the
SPIF bit.  However, randomly the SPIF bit is never raised, thus leaving
you deadlocked awaiting that bit.
My, rather inelegant, solution was to put a max interation count to the
loop and record the max value of the loop when it found a valid SPIF
bit.  Then I took that value and increased it to what I felt was a
"worst case" loop value.
So far this has worked, the SPI has run for many hours servicing the
UARTs under moderate load without a lockup or noticable data loss.  I am
concerned that although this does work (the max count) it may be that
later, when the product is released, that data loss may show up!
The SPI of the LPC2106 seems to be rather fragile...
TomW
>Brendan
>Yahoo! Groups Links
Re: SPI Code hangs
I'd guessed you'd seen it OK, but just in case you weren't aware of
it....
The behaviour you describe certainly seems odd, and like you say,
though the work-around works, I'd be a bit worried too that it could
fail (on the basis that it's to get around unexplained rather than well
understood behaviour).
I'd be inclined to reduce the software as much as possible to try and
isolate the behaviour. This will either identify the source of the
problem, or if not, should give something small and manageable that
Philips could take a look at.
Let us know the outcome if you go down this route.
Brendan
2006-03-10 by Robert Adsett
At 08:16 AM 3/10/2006 +0000, Danish Ali wrote:
>That's a very useful page. (I can't vouch for the chinese-like
>text at the bottom) but I still say it should be an _official_
>Philips document, so those who start with (say) an lpc2148 and
>then say "I need more pins" can move to an lpc2294 knowing the
>areas which require attention even if they only know documents
>from Philips.
It might be nice but the wiki is capable of responding far faster than
Philips bureaucracy.
Mutter, spammers.  Spam removed from various pages now.  BTW community help
in keeping the pages up to date and clean of spam is appreciated (even if
I'm not the owner of the site I feel confident in that statement)
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
