Lpc2000
Can't Receive Data on UART0
2006-03-11 by Nice Guy
I have tried everything I can think of, but I can not receive data on
the UART.  I know the UART and all other hardware is good, because I
can program the part over the exact same setup.  All I want to do is
send anything I receive back out, Just emulate a loopback as a first
step.  I can send data out the uart all day long. Below is my code, I
must be doing something stupid.  VPB Clock is set the same as the PLL
clock. Thanks for any help.
int main(void)
	sysInit();                              // Init system stuff
	uart0Init(9600, UART_8N1);
	uart0Puts("UP!\n\r");
	while(1)
		uart0Putch(uart0Getch());
	return(0);
int uart0Init(int baud, int mode)
	// clear needed pinsel bits and set to correct values
	PINSEL0 &= ~(PINSEL_FUNC(3,1)|PINSEL_FUNC(3,0));
	PINSEL0 |= PINSEL_FUNC(1,1) | PINSEL_FUNC(1,0);
	U0LCR = BIT7|mode;
	U0DLL = ((XTAL * M_OSC) / (baud * 16)) & 0xFF;
	U0DLM = (((XTAL * M_OSC) /(baud * 16)) >> 8) & 0xFF;
	U0LCR &= ~BIT7;
	U0IER = 0x00;             // disable all interrupts
	U0IIR = 0x00;             // clear interrupt ID register
	U0LSR = 0x00;             // clear line status register
	U0FCR = BIT2|BIT1|BIT0;
	return(0);
int uart0Putch(int ch)
  while (!(U0LSR & BIT5))          // wait for TX buffer to empty
    continue;                           // also either WDOG()
  U0THR = (unsigned char)ch;  // put char to Transmit Holding Register
  return (unsigned char)ch;      // return char ("stdio-compatible"?)
const char *uart0Puts(const char *string)
	char ch;
	while ((ch = *string)) {
		if (uart0Putch(ch)<0) break;
		string++;
	return string;
int uart0Getch(void)
	if(U0LSR & BIT0)
	return U0RBR;
	return -1;
Re: [lpc2000] Can't Receive Data on UART0
2006-03-11 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Saturday, March 11, 2006 7:11 PM
Subject: [lpc2000] Can't Receive Data on UART0
Rowley CrossStudio for ARM  has an example. I think it worked OK when I
tried it.
Leon
2006-03-11 by Karl Olsen
---- Original Message ----
Sent: Saturday, March 11, 2006 8:11 PM
> int main(void)
> while(1)
> return(0);
> U0LCR = BIT7|mode;
> U0LCR &= ~BIT7;
> return(0);
> char ch;
> string++;
> return string;
> if(U0LSR & BIT0)
> return U0RBR;
> return -1;
Most of the times you call uart0Getch(), no character is received, and it
seems you then send 0xFF.  Is this intended?
Karl Olsen
Re: Can't Receive Data on UART0
2006-03-12 by Nice Guy
> From: "Nice Guy" <mcmurtr@...>
> > int main(void)
> > while(1)
> > return(0);
> > U0LCR = BIT7|mode;
> > U0LCR &= ~BIT7;
> > return(0);
> > char ch;
> > string++;
> > return string;
> > if(U0LSR & BIT0)
> > return U0RBR;
> > return -1;
and it
> Karl Olsen
Yeah, it's fine for now, I want to be able to hold a key down and see
it appear in the output stream. The 0xFF shows up as spaces in
hyperterminal.
Re: [lpc2000] Re: Can't Receive Data on UART0
2006-03-12 by Bill Knight
On Sun, 12 Mar 2006 20:11:36 +0000, Nice Guy wrote:
<snip>
>hyperterminal.
Hyperterminal drops characters.  I suggest you change the code to only
send a character if one is received.
int ch;
if ((ch = uart0Getch()) >= 0)
  uart0Putch(ch);
-Bill Knight
R O SoftWare &
http://www.theARMPatch.com
2006-03-12 by Robert Adsett
><snip>
> >hyperterminal.
Also given Hyperterminal's oddities consider getting something that's more
of a 'real' terminal emulator.  I use realterm but there are others and
several of them are free (including realterm)
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
