What is Fast I/O ?
2006-03-14 by croquettegnu
Hi all, I would like to knwo what is exactly fast I/O because I have not found anything about timing on the LPC214x datasheets... Thanks in advance
2006-03-14 by Hossam Alzomor
Hi I think that fast IO is a feature in recent released versions of ARM. It's an IO's connected directly to AHP of AMBA bus and not throgh APB You can check ARM web site Salam Hossam Alzomor www.i-g.org
2006-03-14 by ian.scanlon
You should refer to the LPC214x *user manual* UM10139. Chapter 8 covers GPIO. The fast GPIO "FIO" is implemented as a second set registers that acess the IO pins much faster. Fig.17 on page 82 shows relitive timing. Very simple to use. Ian --- In lpc2000@yahoogroups.com, "croquettegnu" <croquettegnu@...> wrote:
> > Hi all, > > I would like to knwo what is exactly fast I/O because I have not found > anything about timing on the LPC214x datasheets... > > Thanks in advance >
What about the maximum speed in Mbit/s on these Fast I/O ? --- In lpc2000@yahoogroups.com, "ian.scanlon" <scanlon.design@...> wrote:
> > You should refer to the LPC214x *user manual* UM10139. Chapter 8 > covers GPIO. The fast GPIO "FIO" is implemented as a second set > registers that acess the IO pins much faster. Fig.17 on page 82 shows > relitive timing. Very simple to use. > > Ian > > --- In lpc2000@yahoogroups.com, "croquettegnu" <croquettegnu@> wrote: > > > > Hi all, > > > > I would like to knwo what is exactly fast I/O because I have not found > > anything about timing on the LPC214x datasheets... > > > > Thanks in advance > > >
2006-03-14 by philips_apps
--- In lpc2000@yahoogroups.com, "Hossam Alzomor" <zomorh@...> wrote: > > Hi > > I think that fast IO is a feature in recent released versions of ARM. > It's an IO's connected directly to AHP of AMBA bus and not throgh APB > You can check ARM web site > > Salam > Hossam Alzomor > www.i-g.org > Close but not quite correct, some other devices of other manufacturers have connected the I/O to the AHB bus but there are still some delays on the AHB although it is definitely faster than using the APB (= VPB). The fastest bus in an ARM7 system is the local memory bus. The Philips LPC214x and LPC2101/2/3 have I/O pins connected to the local bus. Max frequency you can achieve is CPU/4 so, a 60 MHz device can generate a 15 MHz output. Keep in mind that this is all CPU driven and while generating a 15 MHz output, you are not going to do anything else. Robert
2006-03-14 by pitstock_kiwi
Thats a pretty good question really. The manual isn't the best thing to clarify this. Heres my take... Fast I/O should always be used as its the norm. The old I/O is just "legacy stuff". You don't use your 56k modem at 14k4 even though it supports it do you? Speed of the I/O.... thats a loaded question. Using Keil C I can get the Pin wiggling at over 3 MHz, (almost half as fast as my Silabs 8051 using C, pardon the pun) Under assembly you can get the port to wiggle at about 15 Mhz (theoretically). This requires certain registers to be frozen to the port address and is not C friendly. One thing about these arm chips is you need to use the hardware as much as possible as thats whats good about them. Bit banging is not their specialty as everything is 32 bits. PS dont forget the fast I/O's are byte addressable if you add some defines to the LPC24??.H Cheers Keith > > > > Hi all, > > > > I would like to knwo what is exactly fast I/O because I have not found
