Problem with hardware flow control of LPC2210 uart
2006-03-14 by Luc Steynen
Hi, I am trying to use the auto-cts feature of the LPC2210 cpu, uart1. To enable it, I have to set the CTSen "Auto-CTS control bit", which is bit 7 in the U1MCR register. But I can not set this bit. It is always read as zero. I can set and read the DTR, RTS and loopback bits in the same register. I have the PINSEL0 bits P0_8 to P0_15 set to 1 to activate the pins as uart handshake lines. Anyone got a clue or a code snippet that uses hardware flow control? Lubine [Non-text portions of this message have been removed]
