Lpc2000
Calculate time.
Calculate time.
2006-03-14 by teddyroskvist
How do i calculate the time?
I have the example you can see herunder.
In the interrupt routine the TOMR0 is set to 149999 because it
should be 10mSec.
But how do i calculate the number? if i need a another time.
void tc0 (void) __irq
  T0MR0 = 149999;                // 10mSec = 150.000-1 counts
  T0IR        = 1;               // Clear interrupt flag
  VICVectAddr = 0;               // Acknowledge Interrupt
	if ((IO1SET & 0xff000000) == 0xFF000000)
		IO1CLR = 0xFF000000;
	else
		IO1SET = 0xFF000000;
/* Setup the Timer Counter 0 Interrupt */
void init_timer (void)
  T0MCR = 3;                        // Interrupt and Reset on MR0
  T0TCR = 1;                        // Timer0 Enable
  VICVectAddr0 = (unsigned long)tc0;// set interrupt vector in 0
  VICVectCntl0 = 0x20 | 4;          // use it for Timer 0 Interrupt
  VICIntEnable = 0x00000010;        // Enable Timer0 Interrupt
int main (void)
	unsigned int i;
	IO1DIR = 0xFFff0000;
	init_timer();
	while(1)
		IO1SET = 0x00FFffff;
		for (i = 0 ; i < 1000000 ; i++ ){}
		IO1CLR = 0x00FFffff;
	return 0;
Re: [lpc2000] Calculate time.
2006-03-14 by Jack Key
The formula is:
  peripheral_frequency=oscillator_frequency*pll_multiplier(if pll is enabled)/vpb_dividor
  So if your oscillator_frequency is 12MHz, pll_multiplier is 5 and vpb_dividor is 4, the peripheral_frequency would be 15MHz. So for 10msec, the count would be:
  Count = peripheral_frequency * time_required
           =   15,000,000 * .01
           =   150,000
  So the count to be loaded in T0MR0 is 150000.
should be 10mSec.
      else
int main (void)
      unsigned int i;
      init_timer();
      while(1)
      return 0;
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors     Pic microcontrollers
  YAHOO! GROUPS LINKS
Yahoo! Mail
Bring photos to life! New PhotoMail  makes sharing a breeze.
Re: Calculate time.
Perfect.
Thank you.
--- In lpc2000@yahoogroups.com, Jack Key <jockey1111111@...> wrote:
> The formula is:
>            =   15,000,000 * .01
>            =   150,000
> should be 10mSec.
>       else
> int main (void)
>       unsigned int i;
>       init_timer();
>       while(1)
>       return 0;
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
> Yahoo! Mail
