Lpc2000
VBAT input on LPC2103 CPU stops when too low.
2006-03-17 by Sagaert Johan
Hi
I see when shorting Vbat to ground the CPU stops running.
So i assume the CPU will also stop when there is an empty battery connected.
The datasheet only has this note :
[4] The RTC typically fails when VBAT drops below 1.6 V.
So i think this does not mean the CPU itself should stop when vbat is too
low.
Are there any issues with this ?
Johan
Re: VBAT input on LPC2103 CPU stops when too low.
2006-03-17 by unity0724
Umm... SRAM inside without power??
One Question:  Do we need 2 diodes outside or the power
switch is already build in the chip??
...beats me...Will try that out when I've my first
LPC2103 board in 2 weeks time.
--- In lpc2000@yahoogroups.com, "Sagaert Johan" <sagaert.j@...>
wrote:
> Hi
connected.
is too
> low.
> Johan
