Lpc2000
JTAG flashing vs. Philips utility- code runs different
2006-03-22 by stephan2148
I use the LPC2148 with Jlink IAR.  I use debug flash in the IAR setup,
so that when I unplug the JLINK the code is already flashed in the
part.  I tried to create a hex file in IAR using extra output in
linker options, and Intel-extended format.  It seemed to work, but
when I use the Philips flash utility, the code seems to run a bit
differently (display glitches sometimes P1.16-P1.23).
Might I be producing the hex file incorrectly, or might some other pin
functions be activating that the JTAG supressed?
Running with the JLINK flashed part runs fine, it's just a hasle.
Thanks for any ideas.
Steve
Re: JTAG flashing vs. Philips utility- code runs different
2006-03-22 by charlesgrenz
Hi Steve,
  You need to set the linker up for IAR as follows:
  Click on "Override default" and put in the filename.hex
  Make sure that debug is unclicked.
  Click on other:
   Output format: intel-extended
   Format variant: 32-bit linear variant
  Modual-local symbols: include all
best regards,
Charles
--- In lpc2000@yahoogroups.com, "stephan2148" <stephan2148@...> wrote:
> Hi,
> Steve
Thankyou,  Charles.
I tried that, but when I do I get a compile error undefined external
_write found in putchar if debug is not selected.  I have read that
this is due to debug mode and the terminal I/O I think, and it tries
to remove it if not in debug mode.
My code however uses printf, and needs it, which I have also read ends
up resolving to _write which I need.
So, it is probably due to debug mode being selected.
Having the parameters you have shown with debug selected to allow
compile, I get the hex file, but with the same problem.
Maybe I will try to download the hex from a JTAG'd part to flash
others if fixing the root cause is too painful.
Steve
--- In lpc2000@yahoogroups.com, "charlesgrenz" <charles.grenz@...> wrote:
> Hi Steve,
>   Click on other:
> best regards,
> Charles
> --- In lpc2000@yahoogroups.com, "stephan2148" <stephan2148@> wrote:
