Lpc2000
scrambled data packet in LPC2148 usb buffer
2006-03-22 by y3peng
Hello all,
I am new to this group and to the LPC chips in general.
I have been working on implementing an USB device using LPC2148.
When the chip read in packets of data from the host PC, occasionally,
a byte goes missing. I checked the data packets over an USB analyzer,
and they appeared to be perfect. So the data got corrupted somewhere
between acknowledging the data packet and reading the data from the
USB endpoint RAM.
It might be of interest to you that I used a modified USB stack from
the virtual com port example from phillip's website. The example was
written for Keil, but it was ported to IAR workbench.
Sometimes the chip also hangs after writing a command to usb protocol
engine, when it waits for CCEMTY to be set.
anyone seen this before?
Eugene
Re: scrambled data packet in LPC2148 usb buffer
2006-03-22 by philips_apps
Please check the update in the latest Keil's example
and use it as the reference. There were some problems
in CC_EMPTY and CD_FULL bit hanging issue in the older
Keil's example, and these bugs have been fixed already.
But, the fixes have not been merged into the Virtual
COM port driver yet.
Find out the differences between the two for now, we
will update the Virtual COM port driver example shortly.
Philips app.
--- In lpc2000@yahoogroups.com, "y3peng" <eugene.peng@...> wrote:
> Hello all,
occasionally,
analyzer,
somewhere
> USB endpoint RAM.
from
was
protocol
> Eugene
2006-03-23 by philips_apps
Hello Eugene,
that might seem off topic but please try to increase the frequency to
the USB peripheral.
There is a parameter in a SFR called VPBDIV and the default is set to
divide the CPU frequency by 4. Running at 48 MHz or 60 MHz this
results in 12 or 15 MHz clock for the USB perpheral which is connected
to the VPBBUS which is equivalent to the ARM APBBUS.
If not done so already please modify the VPBDIV to divide by 2 instead
of divide by 4. We have noticed some occasional problems going away
when we did this.
Hope this helps, Bob
> Hello all,
> USB endpoint RAM.
> Eugene
2006-03-23 by Jayasooriah
Hi Bob,
Sorry to butt in on this, but IMHO doing what you recommend is not a good
thing.
Transient and/or intermittent problems are difficult to track down. Doing
what you suggest for the reasons you suggest only serves embed the problem
deeper in the scheme of things.
If one is interesting in fixing the problem at its source, I would not
recommend changing anything without justification.
Hope you take the post in the right way.
Jaya
 > when we did this.
Send instant messages to your online friends http://au.messenger.yahoo.com
RE: [lpc2000] scrambled data packet in LPC2148 usb buffer
2006-03-23 by Joel Winarske
Hi Eugene,
> Hello all,
> USB endpoint RAM.
Since you're working with IAR, be sure to take a look at the MSD example
project.
It can be found here:
<install drive>\Program Files\IAR Systems\Embedded Workbench
4.0\arm\src\examples\Philips\LPC214x\MassStorage_USB_LPC2148
It is a major revision to IAR's HID example, and a good starting point for
writing LPC2148 device code.
Joel
> project.
I should have mentioned I've had my share of issue's with the Keil USB
stack.  I've ported all the Keil examples to IAR.  In comparison the IAR USB
stack is clean.
This is addressing the problem by the source.
http://groups.yahoo.com/group/lpc2000/message/12923
Philips Apps
--- In lpc2000@yahoogroups.com, Jayasooriah <jayasooriah@...> wrote:
> Hi Bob,
good
> thing.
Doing
problem
> Jaya
instead
>  > when we did this.
RE:scrambled data packet in LPC2148 usb buffer
2006-03-27 by juval
Message: 10
<Subject: RE: scrambled data packet in LPC2148 usb buffer
> <I should have mentioned I've had my share of issue's with the Keil USB
<stack.  I've ported all the Keil examples to IAR.  In comparison the IAR
USB
stack is clean.<
Hi Can you send me the IAR ported Keil Examples.
Thanks
Juval
RE: [lpc2000] RE:scrambled data packet in LPC2148 usb buffer
2006-03-27 by Joel Winarske
Hi Juval,
My customer paid for my time to do this, they own it.  So no, I cannot send
them to you.  The changes are ultimately semantics, as IAR is stricter than
Keil.
I would recommend you closely examine the IAR MSD example.  It integrates
DMA, and is much more thorough than the Keil code base.  Cleaner code too.
Joel
