Price list of LPC210x controllers
2006-03-23 by vineet jain
Hello Group,
Sorry if the list is already posted, but could I get the link where I could find the price list of these controllers.
Vineet.
Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
[Non-text portions of this message have been removed]2006-03-23 by Tom Walsh
vineet jain wrote: >Hello Group, > Sorry if the list is already posted, but could I get the link where I could find the price list of these controllers. > > > Goto the Philips website (http://www.standardics.philips.com/), click on "Contact us", then click on "Locate a Sales Office or Distributor <http://www.standardics.philips.com/sales/>", locate your country / region, ..., then contact Philips. TomW > Thanks, > Vineet. > > >--------------------------------- >Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates. > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > > > > > > -- Tom Walsh - WN3L - Embedded Systems Consultant http://openhardware.net, http://cyberiansoftware.com "Windows? No thanks, I have work to do..." ----------------------------------------------------
2006-03-23 by Herbert Larbie
Hi, I am new to the lpc2xxx devices, does anyone have some crossworks examples for programming this device (led flashing that type of thing) that they could let me have. Thanks in advance. Herbert Larbie
2006-03-23 by Leon Heller
From: "Herbert Larbie" <h.larbie@...> To: <lpc2000@yahoogroups.com> Sent: Thursday, March 23, 2006 11:13 AM Subject: [lpc2000] crosswork examples for Olimex LPC-H2214 > Hi, > > I am new to the lpc2xxx devices, does anyone have some crossworks > examples for programming this device (led flashing that type of > thing) that they could let me have. Lots of examples are provided with Crossworks. Help - Contents - Welcome will take you to them (Getting Started example programs). Some of them are intended for use with Olimex hardware. Leon -- Leon Heller, G1HSM leon.heller@... http://www.geocities.com/leon_heller
2006-03-23 by Peter Jakacki
Has anyone had experience with sharing the crystal over multiple LPC21xx oscillators? I have a design where I am multidropping 2101s together over the SPI bus (slave listen, master to talk). It seems a bit over the top to have a separate crystal for each chip though and I am looking at running the XTAL out from one chip to the XTAL in of another and so on (to reduce loading). Of course, the line length will be short and shielded. Has anyone actually done this? Are there problems that you may have actually experienced? (Notice the "actually" :) ) Have you perhaps had problems with similar arrangements? I have done this with other types of chips before and I can see no problem with doing the same with the LPC21xx. Oscillator output levels look fine and are in the 0.3 to 1.6V range which on the oscillator's 1.8V unbuffered gate indicates strong drive. *Peter*
2006-03-23 by Karsten Weiss
Hello Peter, some time ago, I clocked a FPGA and a LPC2292 by a single source. I used a quarz oscillator with a 3.3V signal output (rather than a single quarz). In the LPC's datasheet you can find a specification on how to do this: Since the XTAL input of the LPC has a 1.8V logic input rating, you will need a 100pF decoupling capacitor between the output of your LVTTL oscillator and the LPC's XTAL input. In my application, this worked well... Karsten Peter Jakacki schrieb:
>Has anyone had experience with sharing the crystal over multiple LPC21xx >oscillators? I have a design where I am multidropping 2101s together >over the SPI bus (slave listen, master to talk). It seems a bit over the >top to have a separate crystal for each chip though and I am looking at >running the XTAL out from one chip to the XTAL in of another and so on >(to reduce loading). Of course, the line length will be short and shielded. > >Has anyone actually done this? >Are there problems that you may have actually experienced? >(Notice the "actually" :) ) >Have you perhaps had problems with similar arrangements? > >I have done this with other types of chips before and I can see no >problem with doing the same with the LPC21xx. Oscillator output levels >look fine and are in the 0.3 to 1.6V range which on the oscillator's >1.8V unbuffered gate indicates strong drive. > > >*Peter* > > > > >Yahoo! Groups Links > > > > > > > > > >
2006-03-23 by Karl Olsen
--- In lpc2000@yahoogroups.com, Peter Jakacki <peterjak@...> wrote: > Has anyone had experience with sharing the crystal over multiple > LPC21xx oscillators? I have a design where I am multidropping 2101s > together over the SPI bus (slave listen, master to talk). It seems > a bit over the top to have a separate crystal for each chip though > and I am looking at running the XTAL out from one chip to the XTAL > in of another and so on (to reduce loading). Of course, the line > length will be short and shielded. > > Has anyone actually done this? I haven't, but when I needed 11.0592 MHz for both an LPC2148 and another chip, I had a crystal on the LPC2148, and used the PLL and the PWM timer to get a 11.0592 MHz square on a PWM output. (The other chip needed TTL levels so I couldn't use the xtal signal directly.) Karl Olsen
2006-03-23 by rtstofer
Another key to success with CrossWorks: let the wizard create the solution and be certain you select the proper Project Type and ultimately the proper target. This is critical for getting the proper system files included in the project. There are several excellent samples for the LPC2106 which I am using. The only issue is to be certain to open as a solution and grab the Olimex_LPC_P1.hzp solution file. After that, everything will work nicely. Richard --- In lpc2000@yahoogroups.com, "Leon Heller" <leon.heller@...> wrote: > > ----- Original Message ----- > From: "Herbert Larbie" <h.larbie@...> > To: <lpc2000@yahoogroups.com> > Sent: Thursday, March 23, 2006 11:13 AM > Subject: [lpc2000] crosswork examples for Olimex LPC-H2214 > > > > Hi, > > > > I am new to the lpc2xxx devices, does anyone have some crossworks > > examples for programming this device (led flashing that type of > > thing) that they could let me have. > > Lots of examples are provided with Crossworks. Help - Contents - Welcome > will take you to them (Getting Started example programs). Some of them are
> intended for use with Olimex hardware. > > Leon > -- > Leon Heller, G1HSM > leon.heller@... > http://www.geocities.com/leon_heller >
