Lpc2000
newbie question - booting
2006-03-24 by kathy_wright_ca
I've been developing code for several months on the Keil 2130 board
with a 2138 - no problems I haven't been able to figure out so far.
Now I have my new board with 2136 and it doesn't appear to be booting.
I've compiled with Keil target info set as 2136 and as 2138 and they
both run on the demo board.  On the new board it gets through the first
few LDR in the startup code, then gets stuck somewhere up in the boot
sector.  I've also probed the flash memory contents  on both boards.
The code is actually different at 0x00000000 but looks the same at the
end.
Do I need to set something else in the compiler?  Do I need to set
something for the boot mode (I'll be reading up on that in the menn
time).  Any hints/advice is appreciated.
Kathy
Re: newbie question - booting
2006-03-24 by roger_lynx
--- In lpc2000@yahoogroups.com, "kathy_wright_ca"
the end.
Hello Kathy,
Your observation might be worth looking more into. At reset, the
program counter, PC, is loaded with address 0x0000 0000  that contains
instruction which loads into PC the address of  the reset vector
(jumping over other entries in vector table), like this:
            org 0x00
            ldr pc, [pc, #0x18]
When this instruction is executed, the PC is 8 bytes ahead (2 words),
so the PC=0x8+0x18 =0x20.
At 0x20 there is an address of startup's "first" instruction.
It is really the third, but I mean this "first" from a programmer's
point of view, hm?  Two "hops" of the PC are given (0x0 -> 0x20 ->
your  first instruction)
BTW, using ldr pc, [pc, 0x18] makes the second hop to any address in 4
GB space, which is good, but in case of your board, not so good. The
code has to be *identical*, not "actually different at 0x0000000".
This why the code beginnings have to match.
That is the theory, how do you load the program to FLASH?
JTAG, UART/bootloader?
Can you you compare the HEX files?
Good luck.
Best regards
Roger
> Kathy
Re: [lpc2000] newbie question - booting
2006-03-24 by Tom Walsh
Your best bet is to get some type of JTAG running so that you can debug
the code.  Depending on your JTAG, you may need to place a loop at the
startup entry label to give the processor some delay so the JTAG can
reset the board and catch the processor before it starts to excute any
code beyond the delay loop.  This is what I use on the LPC2106 to allow
an Abatron BDI2000 to "catch" the processor:
============ begin crt0.S ================
_start:
start:
      ldr   r0, JTAG2
      ldr   r1, PINSELREG
      str   r0, [r1]       // activate secondary JTAG port.
      mov   r3, #0x10000
startdelay:
      subs  r3, r3, #1
      bne   startdelay     // give debugger time to catch us.
============== snip ===================
The above delay is needed on the LPC2106 as I am switching to the
secondary JTAG and the BDI2000 has no control until that code executes.
On the LPC2138, no loop is needed as it catches the processor nicely at
the first opcode.  With a wiggler (lower speed JTAG device), you may
still need a slight delay loop to catch the processor before it slams
into whatever bad code you have.
TomW
Thanks for your help.  The contents at 0x00000000 were different
because it was in Bootloader mode instead of Flash mode.  This is
because I left P0.14 open and its unintionally entering ISP mode on
reset.  Should be an easy fix with a pullup, we'll see!
-- Kathy
board
far.
debug
can
any
allow
> _start:
> start:
>       ldr   r0, JTAG2
>       ldr   r1, PINSELREG
>       mov   r3, #0x10000
> startdelay:
>       subs  r3, r3, #1
executes.
nicely at
may
slams
> Regards,
> TomW
