How Can I Configure Timer? -To get this
2006-03-25 by Saravanakumar S
Hi all,
I am newbie to this field .Can you please help me to come out of
this problem.
I modify the pgm, to generate the 100KHz frequency with 50% duty
cycle in Timer1 Match 1.1 pin(P0.13 pin)
The modified program is generate correct frequency in polling method
only.It didnt generate the frequency (50% duty cycle) While performing
other tasks.
I want to generate the frequency(50% duty cycle),with out polling method.
Give me some ideas,to generate the 100KHz frequency(50% duty cycle) in any
method.
Herewith this i enclosed my program.
#include <LPC210x.H>
void T0isr(void) __irq;
void main(void)
VPBDIV = 0x00000000; // Configure the VPB divi
PINSEL0 |= 0x08000000; //Match1 as output (P0.13)
T1PR = 0; //Load prescaler
T1TCR = 0x00000002; //Reset timer
T1MR1 = 0x00000048; // Set the on or off time
of cycle
T1MCR = 0x00000018; //Reset on MR1 & interrupt
On MR1
VICVectAddr4 = (unsigned)T0isr; //Set the timer ISR vector address
VICVectCntl4 = 0x00000025; //Set channel
VICIntEnable |= 0x0000020; //Enable the interrupt
T1TCR = 0x00000001; //enable timer
while (1)
void T0isr (void) __irq
T1EMR |= 0x000000C2; /Toggle MAT1 pin
T1IR |= 0x00000002; //Clear match 1 interrupt
VICVectAddr = 0x00000000; //Dummy write to signal end of
interrupt
