Lpc2000
Not getting the Reset and Endpoint0 Interrupts
2006-03-29 by Saritha S
hello,
We are developing USB HID and Core Driver on Olimex LPC2148 board.
The USB _ISR is getting invoked when the USB Cable is plugged out and the
interrupt DEV_STAT_INT is getting invoked.
But when i connect the USB Cable, the Reset interrupt is not getting
generated.
Thanks in Advance
Sarita
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s)and may contain confidential or privileged information. If you are not the intended recipient, please notify the sender or administrator@...
RE: [lpc2000] Not getting the Reset and Endpoint0 Interrupts
2006-03-29 by Joel Winarske
Hi Sarita,
> generated.
Reset triggers DEV_STAT_INT.  You then need to query engine with
CMD_USB_GET_DEV_STAT cmd, as below:
	  // Device Status interrupt
	  if(UsbDevIntrSt.Status)
	    // Clear Device status interrupt
	    DEVINTCLR = bmUSB_DevStatusInterrupt;
	    // Get device status
	    USB_DevStatus.Data = USB_Cmd(CMD_USB_GET_DEV_STAT,0);
	    // Device connection status
	    if(USB_DevStatus.ConnectChange)
	      if(UsbUserFun[UsbConnectEvent] != NULL)
	        UsbUserFun[UsbConnectEvent]((void *)USB_DevStatus.Connect);
	    // Device suspend status
	    if(USB_DevStatus.SuspendChange)
	      if(UsbUserFun[UsbSuspendEvent] != NULL)
	        UsbUserFun[UsbSuspendEvent]((void *)USB_DevStatus.Suspend);
	    // Device reset
	    if(USB_DevStatus.Reset)
	      USB_HwReset();
	      if(UsbUserFun[UsbResetEvent] != NULL)
	        UsbUserFun[UsbResetEvent](NULL);
Re: [lpc2000] Not getting the Reset and Endpoint0 Interrupts
2006-03-29 by Bertrik Sikken
Saritha S wrote:
> hello,
> generated.
Perhaps you forgot to clear the DEV_STAT bit so you got only 1
device state interrupt? Normally you should indeed see a reset when
connecting the device to a USB host.
Bertrik
2006-03-30 by Saritha S
Hello
pls find below the USB ISR and the Init functions.
Let me know if  i have to do any further initializations for getting the
Reset and the Endpoint0 interrupts
_attribute__ ((interrupt ("IRQ"))) LPC_USB_ISR(void){
 UINT32 uiInterrupt = 0;
 UINT32 uiInterruptval = 0;
 uart0Puts ("\rEntered ISR\n");
 /* set the uiInterrupt to the Device Interrupt Status Register */
 uiInterrupt = DEV_INT_STAT;
 if (uiInterrupt & DEV_STAT_INT)
  DEV_INT_CLR = uiInterrupt;
  VICVectAddr = 0;
  WrCmd(CMD_GET_DEV_STAT);
  uiInterruptval = RdCmdDat(DAT_GET_DEV_STAT);
  /* If the Reset bit is set,then invoke ResetUSB() to reset the USB Device
  if (uiInterruptval & DEV_RST)
      uart0Puts ("\rReset  Interrupt\n");
    ResetUSB();
   goto ISREnd;
  if (uiInterruptval & DEV_SUS_CH)
     if (uiInterruptval  & DEV_SUS)
     else
   goto ISREnd;
  } /* End of if (val & DEV_SUS_CH) */
    /* If the Connection Status is changed */
  if (uiInterruptval & DEV_CON_CH)
   uart0Puts ("\rConnection Change  Interrupt\n");
   /* Clear the and acknowledge the interrupt received */
      goto ISREnd;
 } /* End of if (uiInterrupt & DEV_STAT_INT) */
  *If the interrupt received is Endpoint's Slow Interrupt on the Control
  * EndPoint
 if (uiInterrupt & EP_SLOW_INT)
  uart0Puts ("\r EP Slow Interrupt\n");
  while (EP_INT_STAT)
   /* Clear the Endpoint Interrupt */
   EP_INT_CLR = 1;
     while ((DEV_INT_STAT & CDFULL_INT) == 0);
   uiInterruptval = CMD_DATA;
    if (uiInterruptval & EP_SEL_STP)
     * Invoke USB_Enumeration () of the USB protocol Module to
     * parse and process the Setup Packet received
     USB_Enumeration ();
     goto ISREnd;
  } /* End of while (EP_INT_STAT) */
 } /* End of if (uiInterrupt & EP_SLOW_INT) */
ISREnd:
 uart0Puts ("\r Reached ISR End \n");
 VICVectAddr = 0;
} /* End of LPC_USB_ISR () */
UINT32
InitializeUSB (UINT32 uiType, UINT32 uiTimeoutvalue)
   /* Select the USB Link */
   PINSEL1 &= ~0xC000C000;
   PINSEL1 |=  0x40004000;
   /* Turn On USB PCLK */
   PCONP |= 0x80000000;
   /* Configure the 48MHz USB Clock and the Fosc */
   PLL48CFG  = 0x23;
   PLL48CON  = PLLCON_PLLE;
   PLL48FEED = 0xAA;
   PLL48FEED = 0x55;
   /* Wait for PLL Lock */
   while ((PLL48STAT & PLLSTAT_PLOCK) == 0);
   /* Enable & Connect the PLL */
   PLL48CON  = PLLCON_PLLE | PLLCON_PLLC;
   PLL48FEED = 0xAA;
   PLL48FEED = 0x55;
   /* Set the USB ISR, the IRQ Slot and Enable the USB Interrupt */
   VICVectAddr0 = (unsigned int)LPC_USB_ISR;
   VICVectCntl0 = 0x20 | 22;
   VICIntEnable = 1 << 22;
   /* Enable the Device Status Interrupt */
   DEV_INT_EN = DEV_STAT_INT;
 /*Reset USB*/
/* Load endpoint index Register with physical endpoint no.*/
 EP_INDEX = 0;
 /* Load the max packet size Register */
 MAXPACKET_SIZE = USB_MAX_PACKET0;
 EP_INDEX = 1;
 /* Wait till endpoint realization is complete */
 while ((DEV_INT_STAT & EP_RLZED_INT) == 0);
 /* Clear all the Endpoint interrupts  */
 EP_INT_CLR  = INT_CLEAR;
 /* Enable the Control Endpoint Interrupt */
 EP_INT_EN   = CNTRL_EP_ENABLE;
 /* Clear the Device interrupts */
 DEV_INT_CLR = INT_CLEAR;
 /* Enable the Devcie Interrupts */
 DEV_INT_EN  = DEV_STAT_INT | EP_SLOW_INT;
/* set the default address */
 WrCmdDat(CMD_SET_ADDR, DAT_WR_BYTE(DEV_EN | 0));
/* make the softconnect active *./
  WrCmdDat(CMD_SET_DEV_STAT, DAT_WR_BYTE(DEV_CON));
  return uiErrorCode;
} /* End of InitializeUSB () */
  From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf Of
Joel Winarske
  Sent: Thursday, March 30, 2006 1:16 AM
  To: lpc2000@yahoogroups.com
  Subject: RE: [lpc2000] Not getting the Reset and Endpoint0 Interrupts
  Hi Sarita,
  > generated.
            // Device reset
              USB_HwReset();
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
