Speech Recognition Software
2006-03-30 by dsidlauskas1
I'm looking for some simple speech recognition software to run on a 2138. It only need recognize imdividualy spoken numbers and letters, and a few words such as "yes" and "no". Does anyone have a suggestion? Thanks, Dave Sidlauskas
2006-03-30 by Leon Heller
From: "dsidlauskas1" <dsidlauskas@...> To: <lpc2000@yahoogroups.com> Sent: Thursday, March 30, 2006 4:16 PM Subject: [lpc2000] Speech Recognition Software > I'm looking for some simple speech recognition software to run on a > 2138. > > It only need recognize imdividualy spoken numbers and letters, and a > few words such as "yes" and "no". > > Does anyone have a suggestion? Speaker-independent or -dependent? If the latter, the old technique of using a bank of op-amp band-pass filters and comparators, implemented in software, should work. Many years ago I played with a speech recognition unit for the TRS-80 that used that technique, and it worked quite well. The microphone had a PTT button, IIRC, and one pressed the button, spoke the word, and released it. The system had to be trained several times on each word; the software averaged the values and stored a template. When recognising words, the utterance was analysed by the filters and compared with each template in turn, and the best match was output as the recognised word. I think it could handle a maximum of 32 words. These days, one would use an FFT for the frequency analysis. Leon -- Leon Heller, G1HSM leon.heller@... http://www.geocities.com/leon_heller
2006-03-31 by dsidlauskas1
Thanks Leon. Unfortunately I need speaker independent recognition. Just the numbers one to 9 would be useful. Dave S. --- In lpc2000@...m, "Leon Heller" <leon.heller@...> wrote: > > ----- Original Message ----- > From: "dsidlauskas1" <dsidlauskas@...> > To: <lpc2000@yahoogroups.com> > Sent: Thursday, March 30, 2006 4:16 PM > Subject: [lpc2000] Speech Recognition Software > > > > I'm looking for some simple speech recognition software to run on a > > 2138. > > > > It only need recognize imdividualy spoken numbers and letters, and a > > few words such as "yes" and "no". > > > > Does anyone have a suggestion? > > Speaker-independent or -dependent? If the latter, the old technique of using > a bank of op-amp band-pass filters and comparators, implemented in software, > should work. Many years ago I played with a speech recognition unit for the > TRS-80 that used that technique, and it worked quite well. The microphone > had a PTT button, IIRC, and one pressed the button, spoke the word, and > released it. The system had to be trained several times on each word; the > software averaged the values and stored a template. When recognising words, > the utterance was analysed by the filters and compared with each template in > turn, and the best match was output as the recognised word. I think it could
> handle a maximum of 32 words. > > These days, one would use an FFT for the frequency analysis. > > Leon > -- > Leon Heller, G1HSM > leon.heller@... > http://www.geocities.com/leon_heller >
