IAP doc/example error for result array size (LPC21xx) ?
2006-03-31 by phmaresh4
All - I've just joined this board to see if there's any info on IAP issues. There seems to be ... a lot. But one particular that I haven't seen mentioned explicitly in any posts (that i could find) is that the "result" array you pass to the iap function should probably be 3 words (12 bytes) rather than just 2 which is what I see in many of the examples. One of the forum users did it right in their EEPROM example, but you have to look pretty closely. I believe that you won't have problems unless you use the "blank check" functionality, which is the only operation which returns three results - the status, the offending offset, and the offending data. Just thought I would draw some attention to this for anyone running into this problem and not having luck searching through the forum archives. Take care, Peter
