Unused ROM data-0 or 0xFF?
2006-04-06 by Saravanakumar S
Hi all,
I am newbie to this field.I am using LPC 2106 for my application.
I write the code to test the unused ROM data.My program size is 500
bytes.After 500 bytes, remaining bytes are unused ROM space only
May be the unused ROM data will be either 0x00 or 0xFF ?
My code :
void main (void)
unsigned int Output=0,Pass=0;
Output=ROM_Check(0x00000800,10);
if(Output == 0)
Pass=0;
else
Pass=1;
unsigned int ROM_Check(unsigned int *Start_address,unsigned int ROM_Size)
unsigned int c;
for (c = 0; 0 < ROM_Size; ROM_Size- -)
c += *Start_address;
Start_address++;
return (c);
But, when I check the ROM data, I am getting different kind of data like
this EF D5 EA E4 EE D0 F6 D0 E3 FA
I want to know whether it is correct or not ?
What will be the unused ROM data?
For Each cycle of operation,I want to check the unused ROM space,to ensure
the Microcontroller status.How can I achieve this one.
Please tell me Where I done a wrong thing?
S.Kumar
