Lpc2000
LPC2106 flash memory modification by programming!!!
2006-04-17 by lpc.lover
hello everyone,
I would like to know if it is possible to modify information writes in
the flash of LPC2106?
I want to realize a little program for receive flash hex file by
serial port of the LPC2106, and the LPC2106 write it in the flash by
programming!!
That can see like : send hex file -> receive hex file in memory sram
-> write in flash memory.
Thank you for a help or idea :)
sorry for my bad english :p
Re: LPC2106 flash memory modification by programming!!!
2006-04-17 by jayasooriah
--- In lpc2000@yahoogroups.com, "lpc.lover" <lpc.lover@...> wrote:
> hello everyone,
> programming!!
Is this what you want to do?
  http://www.cse.unsw.edu.au/~jayas/esdk/sill.html
Re: [lpc2000] LPC2106 flash memory modification by programming!!!
2006-04-17 by haare_in_der_dusche@yahoo.de
> programming!!
That is possible. The concept is named "boot loader".
Guess what? A boot loader is already present in every 2106 - and it does
precisely what you've described.
It is used by Philips' flash download tool. Connect the 2106's serial
port to a PC, ground some of the 2106's inputs and off you go.
___________________________________________________________
Gesendet von Yahoo! Mail - Jetzt mit 1GB Speicher kostenlos - Hier anmelden: http://mail.yahoo.de
Re : [lpc2000] Re: LPC2106 flash memory modification by programming!!!
2006-04-18 by Xedius Zolva
Yes this is a part of what I want : )
Thank you.
Now I going to think about modify the flash block by block and not all in one time ; )
I want to use MAPPING of hex files to do that.
Do you this is a good idea?
For example if I compare the two hex files I think that some part of there file are the same!!
Specialy when the real difference is the modification of a static value in the code!!
With that I think I can flash 256k of the atmel in 3 times : )
I want to use in the futur a other source than the RS232.
For example by wifi connector on RS232 port for wireless flashing ; )
Thank for all idea.
----- Message d'origine ----
De : jayasooriah <jayasooriah@....au>
À : lpc2000@yahoogroups.com
Envoyé le : Lundi, 17 Avril 2006, 12h16mn 18s
Objet : [lpc2000] Re: LPC2106 flash memory modification by programming!!!
 > hello everyone,
 > programming!!
         YAHOO! GROUPS LINKS
