Lpc2000
DM9000 interface
DM9000 interface
2006-04-19 by rohan patil
hi everybody..
please give me solution for follwing.
i m interfacing dm9000 ethernet controller ic with
microcontoller
i have used memory mapping for interfacing it.
cmd pin is connected to adress line A2
Chip sellect CS is generated by A17=0,A18=1,A19=0
AD0 to AD15 lines are used for address data port of
dm9000
 so veriable DMADDR is at address 40000h
& DMDATA is at address 40004h;
Read write lines of microcontroller are properly
connected to dm9000
in this way can i access the address & data ports of
dm 9000 by accessing DMADDR & DMDATA?
Please help!!!!
Rohan Patil
__________________________________________________________
Yahoo! India Matrimony: Find your partner now. Go to http://yahoo.shaadi.com
[lpc2000] USB CDC standard inf file
2006-04-19 by Marko Pavlin
I would like to use CDC USB class to replace RS232 interface for a
product implemented with LPC2148.
I have some (mostly "windows") questions:
1. Does microsoft provide standard INF file for the CDC driver?
2. If not, is it possible to define inside INF file the port number
(e.g. COM9, COM27 etc..)?
3. Where is "normally" usbser.sys after WINxxx installation?
I am sorry for going slightly offtopic, but it's related to LPC214x.
Marko
Re: [lpc2000] USB CDC standard inf file
2006-04-19 by FreeRTOS Info
To: <lpc2000@yahoogroups.com>
Sent: Wednesday, April 19, 2006 8:51 AM
Subject: [lpc2000] USB CDC standard inf file
> Marko
The FreeRTOS.org download includes a CDC driver (provided by a third party)
for the SAM7.  When interfacing to Windows for the first time Windows just
automatically recognised this and installed the CDC driver, so it must have
a standard inf.  You could copy the descriptors for your LPC version (look
in the lwIP/Rowley demo directory).
On my XP computer usbser.sys is in C:\WINDOWS\system32\drivers.
Richard.
http://www.FreeRTOS.org
*Now for ARM CORTEX M3!*
2006-04-19 by Bertrik Sikken
I'm also working on a USB CDC class driver for the LPC214x.
Not as far as I know.
In my experience, windows just assigns the next available com port.
When resetting the USB CDC device while it is open (e.g. in HyperTerm)
the 'next available com port' is increased. For example, when virtual
COM3 is opened in hyperterm and the device is plugged/unplugged,
COM3 gets 'zombified' and the device is now assigned COM4.
There was some recent discussion about making a USB CDC COM port
persistent on the usb.org discussion forums.
I had to manually extract it from one of the .cab files in
<windows root>\Driver Cache\i386
(driver.cab or sp2.cab)
Bertrik
Re: [lpc2000] DM9000 interface
2006-04-20 by sig5534@hotmail.com
I have a project about to start with LPC2214 and DM9000E for Enet interface, but I have external memory.
What CPU are you using?  Are you trying to get the DM9000 to access the SRAM inside the LPC part?  Not sure if any of the LPC parts have DMA pins for such a purpose.
Chris.
  To: lpc2000@yahoogroups.com
  Sent: Tuesday, April 18, 2006 11:36 PM
  Subject: [lpc2000] DM9000 interface
     hi everybody..
  microcontoller
  dm9000
  connected to dm9000
  Please help!!!!
  Rohan Patil
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2006-04-20 by Marko Pavlin
Thank you!
What "USB stack" do you use? I checked keil USB demos and it looks very
nice. Unfortunately they implemented mass storage, audio and HID class
so far.
Marko
> Regards,
> Bertrik
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2006-04-21 by Bertrik Sikken
I'm using a home-grown USB stack (project lpcusb on sourceforge).
It is basically just a framework for USB devices, handling the hardware
side and "chapter 9" device requests, but it also includes examples for
the HID class and CDC serial port emulation (working on RNDIS ethernet-
over-USB and mass storage).
Bertrik
Marko Pavlin wrote:
> Thank you!
> so far.
> Marko
>> Regards,
>> Bertrik
