Lpc2000
Embedded Artists exceptions in framework
2006-04-20 by frodri123123
I have some code which is causing  a dabort exception.  I am
using an Embedded Artists board (with lpc 2148) with the gnu
debugging environment.  I am trying to debug the code through a
serial console.  Now, when the exception occurs, it gets caught in
the follwing routine:
static void
exceptionHandlerDabort(void)
  register unsigned int programCounter asm ("lr");
  unsigned int          value = programCounter - (unsigned int)0x08;
  consolSendString("Dabort exception !!!\nAddress: 0x");
  consolSendNumber(16, 8, 0, '0', value);
  while(1)
An I get:
Address: 0x00001E80
thrown in the console...  However that address corresponds to:
$ arm-elf-addr2line -e myproject.elf 1E80
../startup/consol.c:263
which is precisely the SendString instruction; so it would seem to
me that value displayed is the current PC, and not the PC where the
exception occurred...
So I guess I am asking:
1- Why is a dabort exception generated?  My understanding is that
they are caused by invalid memory access; however I am not clear as
to what constitues an invalid memory access for the lpc2148.  Is it
unaligned access?  or is it access to non existing memory?
2- Is the exception effectively generated at the consol.c file; or
is there some magic to make the exception handling framework work
properly?
Hope someone can help...
ps.  I am new to the ARM family; so maybe I am just being thick...
Re: Embedded Artists exceptions in framework
2006-04-20 by brendanmurphy37
Data abort exceptions are caused by a signal from the memory system
(i.e. are specific to the ARM implementation). On the LPC2148, see
section 2.3 "Prefetch abort and Data Abort exceptions" for when they
are signalled (basically, references to invalid memory addresses).
The exception is handled by one of the vectors at the exception
vector table - see section 2.2.1 of the usear manual.
The processor loads the address of the aborted instruction (+ 8) into
r14 (i.e.lr) when it happens.
My guess is that the lr has been overwritten by the time your
function has been called.
You could try something like:
_int_vectors:
    ldr  pc, do_reset_addr
    ldr  pc, do_undefined_instruction_addr
    ldr  pc, do_software_interrupt_addr
    ldr  pc, do_prefetch_abort_addr
    ldr  pc, do_data_abort_addr
    nop
    ldr  pc, do_irq_addr
    ldr pc, do_fiq_addr
/* table of interrupt handler adresses */
do_reset_addr: .long	do_reset
do_undefined_instruction_addr:	.long	do_undefined_instruction
do_software_interrupt_addr: .long	do_software_interrupt
do_prefetch_abort_addr:	 .long	do_prefetch_abort
do_data_abort_addr: .long	do_data_abort
do_irq_addr: .long	do_irq
do_fiq_addr: .long	do_fiq
do_undefined_instruction:
    mov  r0, #0
    sub  r1, r14, #4
    b    exception_handler
do_prefetch_abort:
    mov  r0, #1
    sub  r1, r14, #4
    b    exception_handler
do_data_abort:
    mov  r0, #2
    sub  r1, r14, #8
    b    exception_handler
and then have something like:
 * Handle exceptions
 * Called close to startup with the original cause of the re-start
void	exception_handler(int exception_type, int location)
    static const char * const exception_name[] =
        "undefined instruction",
        "prefetch abort",
        "data abort"
    char    buffer[40];
    /* print out the cause of the exception */
    sprintf(buffer, "\r\nEXCEPTION at 0x%08x (%d): %s\r\n",
               location, exception_type,
               exception_name[exception_type]);
    polled_write_to_debug_port(buffer);
    while (1)
    return;
This gets rid of any problems with in-line assembler (!).
Hope this helps
Brendan.
> static void
0x08;
>   while(1)
> An I get:
> Address: 0x00001E80
> properly?
Before anyone points it out, the buffer in the example below isn't
big enough.
Note that for clarity other code has been removed from the original
that this example comes from (e.g. handling other exceptions, checks
for bounds in the array access etc.).
A final point to make is that you clearly have to be careful what
functions you're calling in such a handler, as by definition
something unexpected and bad has happened, and things are probably
not as you expect them (e.g. stack pointer, memory). In particular,
don't try and use interrupts in this mode.
Brendan
--- In lpc2000@yahoogroups.com, "brendanmurphy37"
they
into
> _int_vectors:
>     nop
>     ldr  pc, do_irq_addr
>     ldr pc, do_fiq_addr
>     mov  r0, #0
>     sub  r1, r14, #4
>     b    exception_handler
> do_prefetch_abort:
>     mov  r0, #1
>     sub  r1, r14, #4
>     b    exception_handler
> do_data_abort:
>     mov  r0, #2
>     sub  r1, r14, #8
>     b    exception_handler
>  * Handle exceptions
>         "prefetch abort",
>         "data abort"
>     char    buffer[40];
>     while (1)
>     return;
> Hope this helps
> Brendan.
in
> > static void
> 0x08;
> >   while(1)
> > An I get:
> > Address: 0x00001E80
to
> the
as
it
or
> > properly?
