Lpc2000
RE: Is this ever gonna stop ? / Re: [lpc2000] Re: Summary of Powe r numbers in active
2004-03-22 by Larsen, Morten ActeNO
> From: redsp@... [mailto:redsp@...]
> Sent: Friday, March 19, 2004 6:48 AM
> To: lpc2000@yahoogroups.com
> Subject: Is this ever gonna stop ? / Re: [lpc2000] Re:
> Summary of Power
> numbers in active
> --- In lpc2000@yahoogroups.com, "microbit" wrote:
> > This thread is starting to annoy me (and maybe others too)
> See what I mean... When you are persistent, it ticks off some people.
> Some people just don't get it.
> micro, did you notice that Robert "thanked" me for my persistence?
> That was the only reason that I continued to ask further. If he does
> not like the question or does not want to answer, I think he can
> decide that for himself and respond appropriately.
> I am not here to "stir things up". I think I am making a valid point
> that the information that he is willing to provide to us here, should
> be available to everyone considering the chip. Not many users will
> find their way to this group. Also, not everyone wants to build a
> board just so they can measure the current. I don't think very many
> eval boards provide for current measurement points.
Wrong,
my experience is, that unless the board was designed without 'low-power'
in mind at all (explicitly for use in industrial, off-line powered apps f.ex.),
they are provisioned for current draw measurements (jumper, or zero-ohm resistor etc.)
All Atmel ARM7(i.e. "AT91EBxx")-based boards have this,
as well as ARM9-based. Same goes for every generation of AVR(8-bit MCU)
prototyping boards; STK100/200/300/500. All these MCUs are termed 'low power',
and Atmel is certainly not unique in this respect.
I could list at least a dozen manufacturers w. this option on altogether >100
devkits/protoboards. In short, I would call this a 'common' feature -
what about LPC21xx kits from Keil, IAR, Nohau, Olimex ...??
Rgds:
Morten Larsen
> I do agree about the support. It is very nice to be able to ask
> questions and get them answered quickly. Thanks Robert and the others
> from Philips. You are doing a good job here.
> But like I said, I need the larger 144 pin chip in a smaller package,
> so I am not too worried about the data sheets for myself. I was just
> trying to help. I won't bother you any more... :)
> <*> To visit your group on the web, go to:
> http://groups.yahoo.com/group/lpc2000/
> <*> To unsubscribe from this group, send an email to:
> lpc2000-unsubscribe@yahoogroups.com
> <*> Your use of Yahoo! Groups is subject to:
Re: Is this ever gonna stop ? / Re: [lpc2000] Re: Summary of Powe r numbers in active
2004-03-22 by Alaric B Snell
My Keil MCB2100 has jumpers in the power rails just before they go into
the CPU, which one can detach and replace with a sensitive ammeter, for
that kind of measurement.
ABS
2004-03-23 by lpc2100
Same is true for Ashling EVBA7 board
feature -
into
for
> ABS
Re: Summary of Power numbers in active
2004-03-23 by golssa
Watch out for the Heisenberg uncertainty principle (you change what
you measure): sensitive ammeters work by introducing, and measuring a
voltage drop.
This voltage drop will affect your measurement (reducing the device
current). Either this voltage drop needs to be compensated for, or
avoided by using clip-on type of ammeters that measure the magnetic
field caused by the device-current flowing through a conductor wired
across the power-jumpers. Extech makes very sensitive (0.1mA and 1mA
resolution) clip on meters. Search for Extech modell No: EX-380942
for example.
GM
> feature -
go
> into
ammeter,
> for
> > ABS
