LPC2129 timer0 Startup problem
2006-04-23 by arm_newbie
Hello,
i have the Olimex LPC-P2129 Development-Board, and I use the Keil
µVision3 IDE (Demo Version).
My problem ist the Timer0 interrupt. Everytime I want to built my
program, I get the message
- assembling Startup.s
- Startup.s (368): error: A1516E: Bad symbol `TimerInterrupt0', not
defined or external
what is the Problem?
I have in my main.c a part named "void TimerInterrupt0()", at this
part of the Program should be jumped if the timer0 interrupt is
active.
Startup.s.:
stmfd r13!, {r12, r14} ; save r12 & r14 */
mrs r12, spsr ; save the spsr */
stmfd r13!, {r12}
msr cpsr_c, #0x93 ; switch to Supervisor mode */
stmfd r13!, {r0-r3, r14} ; save Supervisor mode registers */
msr cpsr_c, #0x13 ; enable interrupts */
bl TimerInterrupt0 ; go handle the interrupt, this
;is declared in TIMER.C */
msr cpsr_c, #0x93 ; disable interrupts */
ldmfd r13!, {r0-r3, r14} ; restore Supervisor mode registers */
msr cpsr_c, #0x92 ; switch back to irq mode */
ldmfd r13!, {r12} ; restore spsr */
msr spsr_cxsf, r12
ldmfd r13!, {r12, r14} ; restore r12 & r14 */
stmfd r13!, {r0-r1} ; save r0 & r1 */
ldr r0, =VICVectAddr0 ; update VIC */
mov r1, #0xff
str r1, [r0]
ldmfd r13!, {r0-r1} ; restore r0 & r1 */
subs pc, lr, #0x4 ; return from the interrupt */
main.c:
// Write the values out to the LEDs...
unsigned int green = 0x00002000;
unsigned int yellow = 0x00001000;
IOSET0 = yellow;
IOSET0 = green;
// Wait for half the timer period...
while (*(volatile unsigned long *)TIMER0_TC <
(ulGlobalMaxTimer0Value / 2));
// Clear the interrupt bit within the IR register...
*(volatile unsigned long *)TIMER0_IR = 0xFF;
Thanks for our help
Bye Christian
