Lpc2000
LPC2148 and words on odd addresses.
2006-04-29 by struer_trace
Hey,
I started messing around with an LPC2148 this week, and until now
everything has just been great. The CPU is just amazing compared to
what I have been working with before. I'm porting a project I did for
the HCS12 series of CPU's to this ARM.
But one thing is very different from what I'm used to. This LPC2148
can only access 16bit and 32bits words within even addresses. (As far
as I understand from the manual).
And that has become a problem for me when porting my code. Because I
have a struct like this:
typedef struct {
    uint8       ucJBC[3];                         // Jump to bootstrap
code
    uint8       cOEMid[8];                        // OEM ID Name of
the formatting OS
    uint16      uiBytesPrSector;
    uint8       ucSectorsPrCluster;               //
... etc.
When I compile this it's not possible to get the correct result from
the uiBytesBeSector because it's placed on a odd address. So my
question is... How do I get the correct result from words aligned odd?
And is it really impossible to make a struct like this? Do I really
have to make all my structs byte even or make it purely by 16 and 32
bit words?
I'm using CrossStudio for ARM 1.5 Evaluation and the MAM is set to mode 2.
Thanks in advance!
Best regards
  Jan Thogersen
Re: LPC2148 and words on odd addresses.
2006-04-29 by brendanmurphy37
When you say "it's not possible to get the correct result from
the uiBytesBeSector" is this something you've seen in practice, or
just an assumption you're making?
The language definition allows compilers to place fields within
structures wherever they want. Typically, padding fields are added
to ensure the allignment rules of the target processor are met. This
is why it is dangerous to make any assumptions about how fields are
actually stored in memory.
If you're using such a struct to help define the structure of fields
in memory (e.g. in data recived in a particular format on a
communications link), it is non-portable. You can try and use some
form of "packed" type modifier to try and sort this out, but this is
also non-portable. The safest way around this is to read the data a
byte at a time into your structure.
In summary: if you declare the structure shown below, you shold have
no problems, unless you're doing something that makes assumptions
about how the fields are stored (e.g. type-casting a pointer to such
a structure to a pointer to some other type or memory buffer).
Brendan
--- In lpc2000@yahoogroups.com, "struer_trace" <jan@...> wrote:
> Hey,
for
far
I
> typedef struct {
bootstrap
> code
> the formatting OS
> ... etc.
from
odd?
32
> bit words?
mode 2.
> Thanks in advance!
> Best regards
>   Jan Thogersen
Re: [lpc2000] Re: LPC2148 and words on odd addresses.
2006-04-29 by Jan Thogersen
It makes a lot of sense what you are saying. What I was trying to do was
moving bytes from a SD card into the structure.
The structure was made to follow the format of which the bytes was
aligned on the SD card. I thought that this was a very beautiful way of
doing it. I have seen code grabbing the struct byte by byte. However,
when I ran this code on a HCS12 CPU then I could just make a memcpy into
the struct and that was it. It was way more code size effective and much
nicer to look at.
But I get your point about the portability! So there is two ways I can
solve this problem... Right? Either give the compiler a pragma to pack
the struct and live with the portability problems or rewrite my code to
grab the protocol byte by byte.
Best regards
   Jan
brendanmurphy37 wrote:
> Hi,
> Brendan
2006-04-29 by Robert Adsett
>nicer to look at.
That's about the size of it.  You take a performance hit either way.  With
the pragma you get lower performance and larger code when you access the
structure elements later in the code.  When you use  cracking routines to
load and unload the structure in place of a memcpy you get the obvious
time/size hit at the interface.
"You pays your money and you takes your choice."
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2006-04-29 by rtstofer
I had the same problem when I ported the FAT code from AVRLib to my
LPC2106 project.  I went with the non-portable approach:
struct bootsector710 {
    unsigned int     bsJump:24;
    unsigned char    bsOEMName[8];
    unsigned char    bsBPB[53];
    unsigned char    bsExt[26];
    unsigned char    bsBootCode[418];
    unsigned char    bsBootSectSig2;
    unsigned char    bsBootSectSig3;
    unsigned char    bsBootSectSig0;
    unsigned char    bsBootSectSig1;
#define BOOTSIG0        0x55
#define BOOTSIG1        0xaa
#define BOOTSIG2        0
#define BOOTSIG3        0
} __attribute__ ((packed));  <=== non-portable
I didn't have the ability to change the structure - that's the way the
data is set out on the disk.
These structs are defined and accessed in a single source file.  I can
live with it.
Richard
>#define BOOTSIG2        0
>#define BOOTSIG3        0
>live with it.
Which leads to a third semi-portable possibility
struct bootsectorport {
struct bootsector710 a;
struct bootsectorport b;
And to convert from a to b
b.bsJump = a.bsJump;
memcpy( b.bsOEMName, a.bsOEMName, sizeof(b.bsOEMName));
etc..
A little cleaner looking than massaging byte by byte.  You have to change
how you define the packed structure when porting but that can be confined
to a small area.  Not truly portable but it covers a lot of cases.
Robert
> >nicer to look at.
> With
Ok. Tanks everyone!
I went for the quick fix... The pragma packed worked just fine!
Have a nice day.
Best regards
   Jan
Glad to have been of help, and that you have it working.
It really comes down to the extent, size and structure of the
software which is the "best" approach (if such a thing ever exists).
For example, if you have a lot of code that uses the data structure,
and only one or two places where it has to be copied to an external
system (flash card, comms link etc.) than it's probably worth going
through the pain of producing byte stream encoding/decoding
functions. That way the code will work reasonably efficiently, and
more importantly will work on any target with any compiler (works
with any "endian" system, too, which packing can't sort out).
If on the other hand the structure is very localised to a piece of
code that does the actual copy to/from the external device/system,
you may as well take the simple approach, using "packed" pragma or
modifier, testing to make sure all is well on each system.
Brendan
